Internet unusable tonight!!!
- Internet unusable tonight!!!
04-04-2012 7:28 PM
Basically, my internet is unusable in it's present state.
Re: Internet unusable tonight!!!
04-04-2012 7:31 PM
04-04-2012 7:33 PM
04-04-2012 7:36 PM
adie:quote
04-04-2012 8:21 PM
04-04-2012 8:28 PM
I know it's tonight now, but tomorrow it will yesterday evening, be helpful when posting you say the date and not just tonight.
Dan.
04-04-2012 8:45 PM
04-04-2012 9:17 PM
04-04-2012 9:32 PM
I cannot use sites such as ispreview.co.uk properly or Facebook, jacacmo etc. Most sites that link to connect.facebook.net don't load properly as it hangs forever. I thought it was my pc and router causing it so messed with everything possible no joy. So I grabbed one of uk2's vpn accounts, when connected to their vpn the sites load fine, turn the vpn off they just don't work properly.
My speeds are fine though other than the strange routing.
04-04-2012 9:58 PM
04-04-2012 10:03 PM
I get constant timeouts, specially on sites relying on SSL connections.
Turn on my VPN, the sites all work without any problems!
04-04-2012 10:05 PM
04-04-2012 10:11 PM
Up until 22:06 I was on:
Quote You are currently connected to the gateway known as ptn-ag04.
This is located in Telehouse North.
After a few attempts I got connected to a different gateway:
Quote You are currently connected to the gateway known as pcl-ag01.
This is located in City Lifeline House.
I'm now waiting on this post to load http://www.ispreview.co.uk/index.php/2012/04/confusion-as-uk-isps-struggle-to-adopt-new-broadband-sp... and it's sitting doing: Waiting for platform.linkedin.com
Turn on my VPN, wham, it's loaded!
04-04-2012 10:11 PM
Looking at Jo's post here theres a lot of disconnects. Were those caused by you, if not have you a fault open?
http://community.plus.net/forum/index.php/topic,103722.msg882607.html#msg882607
If you;re suffering that degree of connection drops then there's a very good chace your conenction will suffer poor throughput.
I'm at home and dont have acccess to our internal systems just now. If you've an open ticket, post it up and I'll get someone to review where we are in the morning.
@azagoth
I gather you have a fault open. Post up the ticket i'd and I'll review that in the morning.
M
04-04-2012 10:14 PM
I was disconnecting, in the hope that something might get cleared to speed my super slow broadband up .. The speed just suddenly dropped over the weekend so I was doing everything and testing everything I could to fix it.
