Internet turned off suddenly and can reconnect
Lozzat58
One minute I had an a connection next it was gone. I have orange light tried restarting and its not happening. How stupid there's no help after 8pm. All I want is to get my Internet back up and I need it for work in the morning 😡
5 REPLIES 5
Fixes: 344
Re: Internet turned off suddenly and can reconnect
@Lozzat58 That's the nature of faults - ne second it woks, the next it doesn't.
If the phone test passes, report a broadband problem via: https://www.plus.net/help/report-a-problem/broadband/
Lozzat58
Thank you for the advice I can’t test the line as I sent a text and they replied saying they are testing the lines many thanks let’s hope it can be sorted 😊
You could put your phone area code into the Zen Broadband Status checker to see if there is a known fault or scheduled maintenance in your area ?
Last night I had a ten minute loss of broadband - but I knew it was coming in advance because that checker gives warning of maintenance for the next seven days.
Lozzat58
Thank you I just checked in the link there are no issues or maintenance planned.
Lozzat58
Hi all it has just come back on after they checked the line and said it was all working so don’t know why it went off.
