Internet speed has dropped significantly.
JaM3z
Unfortunately my internet speed has dropped significantly and my latency to game servers has now reached the 2000 ping mark, I followed the information in the sticky at the top of the page and it has pretty much confirmed my suspicions.
I had a problem earlier today in which my ADSL filter was rather unfortunately broken (my master phone socket is right behind the front door), to cut a long story short I was bringing my main PC back indoors just pushed the door open rather hastily (TJ07's weigh a ton) the wind caught the door also and after an almighty smash my filter was in bits on the floor, no problem ill just pop into Maplin's and pick up another filter bought it home and reconnected it all back up, so fare so good everything is working as normal.  Except now when I reconnected to the internet my router is reporting a connection speed of 1280Kb/448Kb which when I normally connect at 4280Kb/448Kb is rather slow.
I've reset my router once every hour since about 3PM and I still can’t get it to reconnect at my usual speed, in fact at one point it was reconnecting at 120Kb/448Kb.  Everytime I reconnect I run a speed test via www.speedtest.net this is my results:
I just ran a BT Speed test and got this:
Download speed achieved during the test was - 871 Kbps
For your connection, the acceptable range of speeds is 200-1000 Kbps.
Additional Information:
Your DSL Connection Rate :1280 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 1000 Kbps
This basically confirmed my original thought that my IP Profile had been changed via BT, any suggestions on what to do to get my full speed back?  Should I be restarting my router every hour or should I just leave it and restart it again tomorrow morning?  Is there anything else I can do to get this sorted out?  Because going from 380KB/s download speed to 20KB/s-80KB/s is really rather a pain.
nebula
Re: Internet speed has dropped significantly.
I'm having the same appalling speeds:
...my profile from the BT speedtester is: 6500 Kbps so I think something else is up. I'm connected to the thn-ag2 gateway.
pierre_pierre
A) there was this problem Yesterday http://usertools.plus.net/status/archive/1263229377.htm
B) reconnecting after 3 pm makes your condition far worse, best is morning from about 9:00.  and dont do it too often BT will think you have a fault and drop your profile
Fixes: 10
JaM3z
Your current low sync speed is not caused by the IP Profile, it's the other way round, the IP Profile is set according to your lowest recent sync speed. You need to sort out why you are not syncing at your previous speeds.
The most likely reason is that following your accident, BT has raised your target noise margin and as a result you are syncing at a lower speed. Could you post the current stats reported by your router (sync speed, attenuation and noise margin) please. If you also have the figures from before the accident that would be brilliant. It could be that there is a problem with your new filter (or the accident in some way damaged the router).
As you have the filter and router in the master socket, have you considered using a filtered face plate which maybe safer (and is certainly tidier)? It also removes the need for filters in other extension sockets.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Fixes: 10
nebula
Those speed tests were taken at just about the worst time possible. Loads of people kick off downloads at midnight to take advantage of the free overnight usage and the system takes an absolute hammering for one or two hours.
JaM3z
Right well ive just reset the router and reconnected, i am now getting a sync speed of 1344Kb/448Kb.  Rather unfortunatly i cant give you other details that you want because my router simpley doesnt give them to me its only a fairly old belkin.
This is a speedtest after the re-sync
Fixes: 10
Quote from: JaM3z
Are you sure? http://www.kitz.co.uk/adsl/frogstats.php might help.
JaM3z
Ok today i went out and bought a new router, its plugged in to the master phone socket i also bought all new filters and this is now what i get.
ADSL
  Type Interleave Path
  Status SHOWTIME
Downstream Upstream
  Data rate(Kbps)
224Kb 448Kb
  Noise Margin
11 20
  Output power(dBm)
125 125
  Attenuation(dB)
40 22
Fixes: 10
Have you got other telephone extension sockets? If so can you plug the router in to the test socket inside the master socket without a telephone and post the router stats again (don't bother running the speed test - all we interested in at the moment is the downstream sync speed and noise margin). Once you've got a copy of the stats you can plug the telephone in if it is needed.
Test socket
JaM3z
This is plugged in directly to the test socket, with no filter (i had a spare cable able to do this), i would like to point out that i could get that sync speed with everything just plugged in normal however i would take a few router restarts to get it at that sync speed.
ADSL
  Status SHOWTIME
Downstream Upstream
  Data rate(Kbps)
704 448
  Noise Margin
13 24
  Output power(dBm)
124 137
  Attenuation(dB)
42 22
EDIT:  Just moved the router back to where it normaly is, re-connected all the filters and am now getting:
ADSL
  Status SHOWTIME
Downstream Upstream
  Data rate(Kbps)
736Kb 448Kb
  Noise Margin
13 23
  Output power(dBm)
123 137
  Attenuation(dB)
42 22
I'm totally baffled by this i now sync higher than if i use the master socket  Undecided
With attenuation of 42dB you should get speeds over 6mbps.
The higher target margin (looks like 12dB at present) would slow that a bit, but nothing like you're seeing.
This suggests something else is damaged or faulty, possibly even a broken wire? Does the phone work OK?
pierre_pierre
and he got that speed earlier, something bad today
Quote from: JaM3z
  Downstream Upstream
  Data rate(Kbps) 224Kb 448Kb
  Noise Margin 11 20
  Output power(dBm) 125 125
  Attenuation(dB) 40 22
JaM3z
Phones in the house work fine, no crackling or distortion etc.
I only have 1 phone plugged in to the master phone socket along with the router which is where i have the filter plugged in, the phone is a wireless base station with 4 seperate phones dotted over the house synced to the master base station.
Try double-filtering the phone, DECT units can sometimes cause problems.
They also have noise suppression, so only an old-style unpowered corded phone should be used for noise tests.
JaM3z
This is with doulbe filtering the phone and i router restart.
ADSL
  Status SHOWTIME
Downstream Upstream
  Data rate(Kbps)
704Kb 448Kb
  Noise Margin
13 24
  Output power(dBm)
125 136
  Attenuation(dB)
42 22
If i go into Member Centre > Conection Settings > High-speed Broadband this is what it tells me:
Telephone number:
   xxxxxxxxxxx
Phone exchange:
   COXTIE GREEN
Estimated line speed:
   2.5 - Checked on 2009-03-10 02:16:31
Current line speed:
   1000
