Internet slow IP profile changed
greenbrucelee
From about 10pm last night my internet has been very slow. I have performed all necessary checks (I have a built in open reach socket and am hard wired).
I have performed a BT whole sale test here are the results
Download speedachieved during the test was - 1.09 Mbps
 For your connection, the acceptable range of speeds is 0.4 Mbps-2 Mbps.
 Additional Information:
 Your DSL Connection Rate :2.05 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM)
 IP Profile for your line is - 1.75 Mbps
I usually get about 6Mbps I am only getting just above 1Mbps
Any advice please?
Fixes: 325
Re: Internet slow IP profile changed
Sorry to hear you're having speed issues.
Testing your broadband service is showing your router in sync at 2048kbps, and testing your line isn't identifying the cause of that. I'd recommend running through the checks here and, if you need to, report the fault to us here.
(It could also be worth trying a different router, if you can)
Let us know if you have any questions or concerns.
greenbrucelee
Neighbours of ours are getting fibre installed today. Could that be an issue? PS have done all the checks. I am now getting 1.75Mbps which is a bit better and I havent done anything
greenbrucelee
apparently theres been a line loop loss and the line thinks its longer than it is, this is being reset hopefully it will work
Fixes: 325
It's possible, but it'd really be speculation in my opinion.
I've performed an SNR reset to reset the IP profile, as that's capping your speed at 1.75mbps.
Can you reboot your router in at least 4 hours time and if your speed doesn't increase, then I'd advise reporting a fault to us using the link I supplied above.
Anoush
greenbrucelee
HI Gandalf
I did what was suggested. It has improved slightly but not much BT wholesale says I am getting 1.9 now plusnet says my line speed is 2Mb.
I have an open reach socket so dont have a filter. Have taken the phone out and just had the cable in, same speed. Funny thing is streaming isn't too bad but downloading is garbage.
I have reported the fault by raising a ticket
Fixes: 160
Behind the faceplate of the Openreach socket there should be an engineer socket, there should be a filter in the router box we provided too. Can you try connecting the router to the test socket and see how the line is performing then.
 Chris Parr
 Plusnet Staff
greenbrucelee
will see if I have a filter but might have got rid of it since I got the open reach socket. BTW I have had this same router since being with plusnet about 8 years could that be an issue?
greenbrucelee
have tried the master socket with a filter and the speed was exactly the same
greenbrucelee
ps now when doing speed test I am getting 0 upload
greenbrucelee
This is todays BT wholesale test (it is different all the time plus last night the extra diagnostic bit was having issues connecting and checking)
Download speedachieved during the test was - 1.92 Mbps
 Your DSL Connection Rate :2.43 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM)
 IP Profile for your line is - 2 Mbps
Fixes: 325
Is your router still in the test socket now?
Testing your line, the IP profile of 2000kbps is capping your speed. I'd advise leaving the router in the test socket and see how it goes. If the connection continues to drop it could be worth trying a different router?
Fixes: 325
P.S. I've reset your line again, please can you reboot the router in about 4 hours?
greenbrucelee
unfortunately I cant leave it in the test socket as I have to unplug the phone. I live with my mother and she has one of those care alarms which is attached to the phone and if you dont have the phone socket plugged in every 10 seconds it shouts the phone isn't plugged in
greenbrucelee
thanks will do
