Internet's on the fritz
Pyrii
My ability to connect to websites keeps going up and down like the yoyo. Is someone letting the cheat play with the on/off switch down there?
But seriously, this is unacceptable, I've tried everything and I keep getting timeouts and fine internet in an alternating pattern.
tumblr_lw369aB5QF1r2zfhn
17 REPLIES 17
SpendLessTime
Fixes: 86
Re: Internet's on the fritz
If it has started today then this thread might have the answer.
Pyrii
Yeah I'm definitely tired of this. I try to read some manga because skype's not working and that's not working, the same with everything.
theaddict
Same here too.
ST14
Supposed 6 hours during the night downtime has become no Internet for a whole day.
Phil_Cleary
I had this problem a couple of hours ago.
In my case, it was a problem with plusnet's DNS server.
I've fixed it by going into the router control panel and unchecking "Obtain DNS Automatically" and inputting the IP's for google's public DNS: Primary 8.8.8.8 Secondary 8.8.4.4.
Would be interested to know if this works for anyone else, or if it's just me!
BenB
Fixes: 20
I'm sorry to hear about this, can you run through these quick checks for me please as they can help http://goo.gl/BZE3NM
theaddict
BenB - those checks didnt help.
Phil_Cleary - WOW...that worked....oh, for 1 minute, then nothing again. Thanks anyway, I enjoyed the 1 minute 😉
Phil_Cleary
BenB - got partway through the troubleshooter but troubleshooter then gave up on me.
theaddict - if the DNS fix worked at all it must mean something - I don't know enough to say what, but maybe it will give tech support a steer on what your problem is?
My connection is now flying - just did a speed test on bt wholesale and getting 19.57 MBps - perhaps because no-one else can connect?
BenB
Fixes: 20
Yeah I've just checked your connection and everything looks fine now and running at a stable rate
Cagney1994
Since there's been problems at PN's end, why not send a text to the customer to let them know what's going on?
A small gesture can go a long way.
theaddict
Well. ..mine seems to of suddenly got some stability. ... for 15 minutes so far !!
But my exchange is listed as down for maintenance again tonight.
Pffft.
theaddict
Correction - dead again.
HarryB
Fixes: 256
We believe that the outage from earlier has been resolved. If you're still experiencing issues and the troubleshooting guide Ben provided hasn't helped, I'd advise raising the matter for further investigation at http://faults.plus.net
 Harry Beesley
theaddict
fault reported yesterday evening
but I actually had internet from about 9pm until midnight..then dead again..so planned work at my exchange ?
today..nothing..again. Not even the 1 minutes worth when resetting router, like yesterday.
SpendLessTime
Fixes: 86
Planned exchange work wouldn't show like that. In most cases you cannot even see the effects of the work done at the exchange.
Glad you reported a fault as it doesn't look good for you.
