Internet red light keeps coming on at random times
- Re: Internet red light keeps coming on at random t...
23-02-2014 9:55 AM
My router (Technicolor TG582N)) keeps dropping the internet connection at random times with the red light showing. The broadband is still a steady green - any thoughts?
Message 1 of 8
(2,450 Views)
7 REPLIES 7
Re: Internet red light keeps coming on at random times
24-02-2014 11:30 AM
A dropping connection is usually due to a fault so I'm going to advise heading here: http://faults.plus.net
Here's a view of your connections over the past week, are you powering the router off at around 9am?
<img src="http://community.plus.net/visualradius/generated/image13932411206345.png"/>
Message 2 of 8
(955 Views)
24-02-2014 12:05 PM
The router is continuously on apart from when I need to reboot it to connect to the internet. We have been with PN about 3 weeks and the download is generally quite good at between 3 & 4mb although the upload is only around 35kbs. We did have problems with an intermittent noisy line when with BT and over 18months had 14 engineers out who found no faults at the time they were here. The router is plugged into the main NT5 socket which was new last year. It makes no difference to speed etc. when plugged into the test socket via a filter. Are we back to the same problems we were having with BT??? Could it be any of the PC settings which is a wired LAN connection? Grateful for any help - it's not a major problem as the internet generally works on a reboot - it's just very annoying! Especially to my wife!
Message 3 of 8
(955 Views)
24-02-2014 5:11 PM
Hi Mike,
You should never need to reboot your router to reconnect. Does it definitely not reconnect unless you do this?
If that's the case I'd like to send you out a replacement router.
Quote when I need to reboot it to connect to the internet
Message 4 of 8
(955 Views)
25-02-2014 8:04 AM
Now seems to be more stable - I think, looking at your chart, we're back to the old intermittent line faults again. Only occasionally did the router connect using the Technicolor Gateway but it now seems OK. The line speed has dropped to around 3.5 which must be the faults - hopefully the profile will recover or the next day or two. BT wholesale speedchecker is telling me that 4mbs is the maximum - it used to be 7.15 when I was with BT - any reason for this? Would it be worth an SNR reset? Thanks for your help. Where can I get the speed details and graphs that I've seen on this site?
Message 5 of 8
(955 Views)
25-02-2014 9:33 AM
Your line isn't looking all that healthy, I think you've probably got a line fault.
Are you able to complete the Fault Checker at http://faults.plus.net?
Message 6 of 8
(955 Views)
25-02-2014 12:45 PM
Thanks Chris - fault checker completed - Broadband is stable at the moment but I think we've still got the same d side line problem that BT couldn't solve (apart from changing the pair!) is there any way I can get a monitor graph?
Message 7 of 8
(955 Views)
07-03-2014 8:29 AM
Openreach found no fault on the line, although after testing the profile dropped from 3.78 to 2.5. He did line reset and all is back to normal. We seem to have an intermittent line problem causing the faults - its been going on for 18 months and we've now had 14 BT engineers to the property - I can't see any chance of it being fixed. I'll just have to put up with rebooting the router. It's interesting that very often the router won't connect to the internet via the Gateway (although the green broadband light is steady) and it does need to be rebooted first.
Message 8 of 8
(955 Views)
