Internet not working
Steffyslingo
We've had plusnet for about a year now, our Internet has stopped working earlier today, we've tried the usual, turning of and on, factory resets, but the light remains solid orange and we are unable to get onto the hub to check any details.
If anyone has any other ideas I'm all ears!
Thanks steph.
7 REPLIES 7
Fixes: 388
Re: Internet not working
If the phone test passes, report a broadband problem via: https://www.plus.net/help/report-a-problem/broadband/
The above assumes you still have 'normal' landline connection - if you have a SOGEA (internet only) one, just use the second link to report a network issue.
Steffyslingo
Hi John,
We don't have a phoneline, we have a broadband only package, does this mean I need to report a problem?
Thanks steph
Fixes: 388
Just use the second link and report a network problem then.
James30
Fixes: 32
@Steffyslingo - feel free to DM us your username and I'll run a test and sort it out.
James - Plusnet Sheffield
Mustrum
Fixes: 81
@James30  Another newbie who can’t yet PM.
willcutforth
Fixes: 113
@Mustrum I popped a PM over to @Steffyslingo  Smiley
 Will Cutforth
willcutforth
Fixes: 113
Just checking back with you to see if you need me to raise a fault for you?
 Will Cutforth
