Internet light was red on 582n, now gone after power down
mancmackem
Hi all,
Internet went off for an hour this morning but i was at work so not sure what exactly happened.
But at the moment the internet light on my router turned red. Left it 5 minutes but no change. Powered off and on router, now no internet light. Powered off and on modem, still no internet light. Still in the training period, denton excange.
Crazy6
Any advice appreciated,
Ta!
28 REPLIES 28
mancmackem
Re: Internet light was red on 582n, now gone after power down
More info, if i disconnect and connect through the router's ews i get the red light then no light with the message "Connection could not be established, Concentrator not reachable".
hooker1uk
could it be there has been a failure on your line or in your area?
mancmackem
Possibly mate, my area isnt listed as having any issues on the bt service status page though (although cabling has been stolen affecting many areas). Ive tried the reset pin button on the router...still no joy.
Poor form jeffrey
D4v3
Hi mancmackem,
I have checked your area and can see no reported outages. As such I would recommend that you continue raising a fault report here: https://portal.plus.net/apps/kbdfaults for us to investigate this further for you.
I hope this helps  Smiley
mancmackem
Hi mate,
Good effort for replying so late. The update is that literally 3 minutes ago the green internet light has returned without me doing anything for about 30 minutes.
Any ideas? Faulty gateway? Hopefully interleaving doesn't get applied to my line after tonight.
I'll update the ticket to ask for it to remain open for 24 hours to monitor with it going off for an hour this morning also.
Cheers!
MM
chrispurvey
Hi MM,
We've seen a few instances where the internet light is red but the services are still working as normal, this isn't anything to be concerned about.
I can see that your line has had a few disconnections and last nights no connection;
<img src="http://ccgi.psmith12.plus.com/visradius/generated/image13681804597645.png"/>
We'll check over your line to see if anything is causing these and we'll report back to you via your fault ticket.
Fixes: 159
Chris,
As with the reports on noisy 582n's is there a case here for 'collecting' some of these devices experiencing "the red is light on but all's OK" syndrome for investigation?
If nothing else, has anyone looked at serial numbers of the reported units to see if they all come from the same production run?
Cheers,
Kevin
newagetraveller
The red internet light has appeared on my 582n, on a few occasions, quite randomly and for no apparent reason. Everything still works as normal though.
However, to get rid of the light I just carry out a "soft" disconnect and connect from within the router's broadband section. Smiley
chrispurvey
Quote from: townman
I'll flag this up again with our products team as there have been more posts made recently regarding this.
mancmackem
Just to be clear in my case Chris, i actually lost connectivity. I could not browse wired or wireless with the red internet light. I then power cycled the router and did not get an internet light at all.
So this doesn't look to be the same situation as the one a few members have posted here where they have had a red internet light but could still browse etc.
I'll check my ticket, it's been fine today.
chrispurvey
Ahhh OK, that is an actual authentication issues then.
I've book in the engineer appointment for you, this is tomorrow(14th) 8am-1pm. I've added the notes you requested although we cannot guarantee anything.
mancmackem
Thanks Chris. It shouldn't be chargeable as I've seen a 25% drop in up and down without any cabling being changed.
mancmackem
Hi Chris,
Doesn't look like the engineer has turned up. Can you chase this for me please? (Ticket 69390742)
Thanks!
chrispurvey
I'm just getting this chased up, it initially appears that further testing has deemed that your line is performing OK and your line has been cleared of any fault so it looks like no engineer will be attending today.
I'll update you ASAP.
