Internet issues for the past 2 weeks.
Dio86
Hi, for the past two weeks at random points of the day my net keeps cutting out on my console and pc.
then the speed drops to near enough unusable speeds, every time i run a speed test it either tells me my download and upload speeds are under 9mbs for d/l and 0.*insert number here* for uploads. ive called 3 times, once was told there was an accident, then another told to change my router, then told they would reset my line as they had found errors,
Ive been with you for years and never had this issue before, is my usage somehow capped or something because its starting to bug me.
Gel
Seasoned Pro
Fixes: 14
Dio86
Re: Internet issues for the past 2 weeks.
i went through all of that before calling. so that doesnt help at all.
Fixes: 19
I am sorry to hear about this. Have you raised this for further investigation with our faults team at faults.plus.net?
 Ben Babinski
