Internet is down again
danielplatt
Can someone please look into this. My router just straight up disconnects the internet randomly and does not automatically reconnect This certainly seems like a router issue rather than a service one. So here I am, unable to remote into my server at home because once again the routers disconnected itself for no damn reason.
All i want is consistent internet, and ever since fiber was installed all i get is rubbish. Help, please.
3 REPLIES 3
adamwalker
Fixes: 221
Re: Internet is down again
Sorry to hear about this. I've just been running some checks and can't see an obvious cause so I'm going to advise heading to http://faults.plus.net to raise a fault and I'm sure we can help you fix that.
Adam
 Adam Walker
danielplatt
Down again today when i got home, again no access to my server all day at work. You won't seen an obvious cause because its not a service problem, the service isn't the problem. The problem is the router is restarting itself and then not connecting again. I no this because the local ip of my server is changing every day i get back meaning it has been assigned a new local IP. This is not caused by a line fault or a service fault as the problem is not necesserily no internet, the problem is the router is physically restarting for no reason, this can only be a router fault. Can someone send me a new router?
the link you provided Adam is no good because my internet is fine, its not the internet that is down or slow, its the router.
adamwalker
Fixes: 221
OK really sorry for overlooking that. One thing we'd need you to do before we'd deal with a replacement is to try a factory reset, the reason being as that can often resolve issues like that without the need for you to wait for a replacement to arrive.
Can you give that a try please and let us know if that's helped? if not we'll get a replacement out to you.
Adam
 Adam Walker
