Internet dropping out
- Internet dropping out
24-07-2016 10:20 PM
Been having this problem on and off for months. Open reach came and checked wires and it carried on. They came again and changed some connection from central area in bloxk of flats to mine.
It's hit and miss on both Ethernet n wireless. Even have powerline units to avoid wireless.
Nothing changed in my flat but last 2 weeks been horrendous. Spend most of time using my iPhone for Internet.
Netflix is a constant buffer. If I'm on Ethernet and use wifi on phone to just tweet or open a page it's so so slow.
Changed channels. This is with one device wireless and one cable Ethernet.
I don't know what else to try. I cannot get fibre here.
Any ideas?
Any ideas?
Message 1 of 2
(405 Views)
1 REPLY 1
Re: Internet dropping out
25-07-2016 10:27 AM
I can see your connection is dropping out fairly frequently so this is very likely to be causing the issues you're seeing. Please report a fault with us over at http://faults.plus.net
Message 2 of 2
(382 Views)
