Internet dropped and now speed has more than halved....
Azagoth
...which, when you're stuck on an ancient ADSL2+ line because OpenReach cocked up and didn't activate our cabinet for fibre, makes the internet pretty much unusable for anything.  I was getting this
EQNfsHd
But now, after the line dropped and reconnected, I'm getting this.
ZnSDSdO
.This is unacceptable.  As you can see, I've been with Plusnet for quite some time now, they used to be a good company, but recently I've found myself thinking that the sooner I can leave this company the better.  I can't even make use of the Prime Video that I'm paying for with this speed.  Will you be reimbursing me for that seeing as how YOU ARE NOT PROVIDING ME THE SERVICE I'M PAYING YOU FOR?
7 REPLIES 7
Fixes: 345
Re: Internet dropped and now speed has more than halved....
@Azagoth You have a fault - not Plusnets issue, but BT/OpenReach's.
If the phone test passes, report a broadband problem via: https://www.plus.net/help/report-a-problem/broadband/
Azagoth
@jab1 Phone line is silent,as always.  But how the hell am I supposed to report a fault when all it says is to text 'HELP' to 07800008121?  How are they supposed to know who I am and which line to check when I'm texting them from my mobile and the fault is with the internet connection, two things that are not connected?  Where is the old broadband fault checker?
If I click through to the 'Help & Support Guides' I only get these options, none of which are applicable to me.
EgB0LDg
Fixes: 345
OK, good the phone is silent, that is one thing less to check. I don't know how the automatic fault-checking bot works (I am no  longer a PN subscriber, nor have I ever used it), but I do know it does, many others have used it and received a solution.
If you don't trust it - use https://faults.plus.net
EDIT: maybe the right-hand option?
Azagoth
Well, I've texted HELP to the number but I'm at a loss as to how they can know which line to check as my mobile (Vodafone) isn't linked to my Plusnet account in anyway and the landline that my internet comes in on isn't provided by Plusnet.  Like I said, this used to be a good company but these days it's absolutely shocking.
Fixes: 542
In that case AIUI the system should text back requesting more information to identify the line
Fixes: 345
As I said, I'm unaware of how the system works, but at a guess, when the text is picked up they will contact you for further details. Presumably you are with BT for the phone?
Fixes: 345
@MisterW great minds. 😉
