Internet disconnects when phone is lifted
- Re: Internet disconnects when phone is lifted
15-06-2013 9:04 PM
First question is unrelated to topic. Is the Technicolor TG582N the only router Plusnet has? It's just that despite living in a tiny house with paper thin walls, venture more than 5 meters from the router and the connection will drop.
On the topic at hand though, this never happened when I was with TalkTalk, Sky or Virgin through the past few years, so why is it happening here?
Message 1 of 3
(892 Views)
2 REPLIES 2
16-06-2013 1:02 AM
The TG582n is the only router which Plusnet supply. Some users report wireless range problems with it but others, including myself, find it works well even into a different flat in my case.
If picking up your phone causes your broadband connection to drop you need to check for a faulty microfilter. Additional guidance can be found in the ADSL Connection Troubleshooting Guide.
David
Message 2 of 3
(443 Views)
17-06-2013 10:56 AM
Hi @MrRight
Whilst the issue you've mentioned can be caused by a fault at the exchange, it's far more likely to be an issue with one (or more) of your filters.
I've also run a line test which doesn't highlight any faults so I'd try changing the filters first.
Let us know how you get on.
Adam
Adam
Message 3 of 3
(443 Views)
