Internet disconnections
MegaPixelMan
For the past few days, every time somebody phones my home phone, my internet disconnects. Other than that it seems to be running fine, its just when the phone rings it cuts out.
I've not experienced this problem since the 90's!
Would it be possible for somebody to check my line to see if there is any faults.
Thanks.
Re: Internet disconnections
It's more likely to be a fault with the filters connected to your phone / digibox / etc. If you can try swapping them out and seeing if the problem persists.
F9 member since 4 Sep 1999
F9 ADSL customer since 27 Aug 2004
DLM manages your line the same way DRM manages your rights.
Look at all the pretty graphs! (now with uptime logging!)
MegaPixelMan
Yeah I can do that.
MegaPixelMan
Put a brand new filter on and the disconnection is still happening when somebody rings my home phone.
Plusnet Staff
Plusnet Staff
Fixes: 5
If it's nothing internal, it's likely to be a Splitter Card issue. If you can raise a fault at http://faults.plus.net we'll be able to get that looked at and fixed for you.
Chris Pettitt
Cloud Environments Engineer
