Internet constantly dropping out
- Re: Internet constantly dropping out
15-04-2013 9:48 PM
in the past hour i have had the following speeds come up, it stays on for anywhere between 0-10 minutes then drops again.
Down: 2304 kbps
Up: 160 kbps
Down: 1984 kbps
Up: 64 kbps
Down: 2272 kbps
Up: 224 kbps
Down: 2272 kbps
Up: 192 kbps
Down: 1856 kbps
Up: 64 kbps
I havent rebooted the router between these different speeds, its just what it is picking up after each disconnect.
Any ideas? it's driving me crazy!
Paul
16-04-2013 10:02 AM
Synch speed will be the 'best that an be achieved' at the time you re synch. Therefore you should avoid doing this during night time hours as generic night time interference (noise) is going to give you a lower synch rate. However, just looking at the Up speed suggests something is very wrong.
A full set of router stats will allow others to determine if these speeds are appropriate for your line.
Beyond that, you'll need to gather some historic data to give to PN.
Ask PN for a radius connection report. This will indicate the frequency of PPP session loss; if it s frequent then clearly there is a problem to be investigated. It is unusual for PPP to survive a synch loss, but I have seen it happen.
Also get and install RouterStats to monitor your router stats CONSTANTLY. This will build up a history of your connection state which you can use to profile the problem. This is essential for identifying obscure problems. I have been monitoring my line since Dec 2012; at times it has identified dozens of disconnections per day... Whilst at present I can use the output to monitor assign electric trains on the West Coast line!
Cheers,
Kevin
16-04-2013 10:09 AM
Quote from: laz3484 and tried it in the master socket.
Was that just in the master socket or in the test socket inside the master socket?
If your master doesn't have a removable lower half you need to try in the master socket with absolutely everything unplugged from all other telephone sockets.
16-04-2013 10:12 AM
16-04-2013 1:02 PM
We're currently testing your line and we'll update you with the results when we have them.
16-04-2013 2:12 PM
Quote from: Oldjim is the line silent when you try the quiet line test 17070 option 2
yes, silent.
When i say master socket i do mean the test one underneath, i only have the 1 extension in the house.
I've got a ticket open for it now, i had BT out this morning and they claim the line is fine. The chaps at plusnet can see that it dropped 20+ times yesterday evening so something is being done
