Internet connection to smart TV failing
CharlotteGrail
Every time we attempt to connect to Amazon Prime or You Tube it fails, says router not in range when is less than six foot away. Any ideas?
2 REPLIES 2
Fixes: 367
Re: Internet connection to smart TV failing
@CharlotteGrail  Welcome to the forum.
If your TV has an Ethernet socket then buy a 6 foot Ethernet cable.
If you have posted on the wrong board and on fibre not ADSL then separate the 2.4 and 5 GHz bands. A google search for 'plusnet 2.4 best practice' will point you to the instructions.
Mads
Fixes: 79
Hello @CharlotteGrail
Thanks for getting in touch with us here.
I'm sorry to read you're having some connection trouble with some of your devices and I apologise for the frustration caused. From what you've said it does sound like a WiFi issue, I'd suggest connecting via Ethernet where possible, if it's not please follow this guide here
Thanks.
