Internet connection lost
xjenbox
So for a few weeks niw, my internet connection has been so slow or disappeared. The last 2 days though, it's totally disappeared. There is a red light on router. I have disconnected it, switched it off, changed filters etc but still nothing! Any suggestions on what to do? It's very frustrating!
Gel
Seasoned Pro
Fixes: 12
Plusnet Staff
Plusnet Staff
Fixes: 115
Re: Internet connection lost
Hello there. Your router appears to be trying to connect using an incorrect password, if you do a factory reset of your router you should be able to bring your connection back.
I've joined the Plusnet Help Team as of May 2017. As such, I have a new forum account. Please direct any queries to @Gandalf. Thanks
 Plusnet Support
Gel
Seasoned Pro
Fixes: 12
...only after he's re entered his PN connection details correctly, and has documents to remind of the default router log in details, assuming not a PN Hub One! (Not all routers show default log in name & p/word on the outside of unit, but in the instructions). Smiley
Or it could have been caused by BREXIT vote perhaps Smiley Smiley Smiley
Plusnet Staff
Plusnet Staff
Fixes: 159
A factory reset avoids the need for this generally as it requests the details back via TR069 again during the setup process.
 Chris Parr
 Plusnet Staff
