Internet connection lost
- Re: Internet connection lost
07-07-2016 10:10 PM
07-07-2016 11:31 PM
08-07-2016 9:22 AM
@xjenbox wrote:
So for a few weeks niw, my internet connection has been so slow or disappeared. The last 2 days though, it's totally disappeared. There is a red light on router. I have disconnected it, switched it off, changed filters etc but still nothing! Any suggestions on what to do? It's very frustrating!
Hello there. Your router appears to be trying to connect using an incorrect password, if you do a factory reset of your router you should be able to bring your connection back.
08-07-2016 11:13 AM - edited 08-07-2016 11:14 AM
...only after he's re entered his PN connection details correctly, and has documents to remind of the default router log in details, assuming not a PN Hub One! (Not all routers show default log in name & p/word on the outside of unit, but in the instructions).
Or it could have been caused by BREXIT vote perhaps
08-07-2016 11:34 AM
A factory reset avoids the need for this generally as it requests the details back via TR069 again during the setup process.
