Internet connection keeps dropping
greshoff
My internet has been stable for a long time however over the past few days the Internet connection keeps dropping then reconnecting. Nothing at my end has changed. Could someone from Plusnet look into this for me.
Thank you.
Plusnet Staff
Plusnet Staff
Fixes: 6
Re: Internet connection keeps dropping
Hi there Smiley
The internet looks stable on our end. Are you using your devices on WiFi?
 Lauren Barry
greshoff
Thanks for checking - my computer is connected via Ethernet cable. Very strange
Plusnet Staff
Plusnet Staff
Fixes: 6
Thanks for confirming. Are you noticing this happen on other devices?
 Lauren Barry
greshoff
I will check the next time it happens. All other devices use wifi
Plusnet Staff
Plusnet Staff
Fixes: 6
Thank you, let us know how you get on.
 Lauren Barry
