Internet connection but no wireless
- Internet connection but no wireless
26-08-2010 9:51 AM
We are able to get a connection using the ethernet cable however unable to connect to the internet via wireless on anything else e.g. lap top, phone, ps3... Help!!
Message 1 of 9
(1,154 Views)
8 REPLIES 8
Re: Internet connection but no wireless
26-08-2010 9:56 AM
and the router is
Message 2 of 9
(765 Views)
26-08-2010 10:16 AM
I'm sorry, I'm not sure what you mean?
Message 3 of 9
(765 Views)
26-08-2010 10:19 AM
Sorry if I'm bein thick! If you mean the model it's TG585 v7
Message 4 of 9
(765 Views)
26-08-2010 10:39 AM
That is what was needed
When you say you can't connect to the internet by wireless can you see the router and/or connect to it from your laptop
Message 5 of 9
(765 Views)
26-08-2010 10:46 AM
Yeah when we plug a laptop into the router it connects to the internet no problem, it's just the wireless we seem to be having issues with. If we search for a wireless connection on a device, sometimes it shows up but can't connect to it and other times it doesnt come up at all. And this is the same on a number of different devices
Message 6 of 9
(765 Views)
26-08-2010 12:32 PM
It may be a duff router - I suggest a call to support and they can run through a few checks then send out a replacement if necessary
Message 7 of 9
(765 Views)
26-08-2010 12:33 PM
Try a firmware upgrade that might help.
Message 8 of 9
(765 Views)
26-08-2010 12:50 PM
Thank you! Will try that!
How do I go about doing a firmware upgrade?
Message 9 of 9
(765 Views)
