Internet connection almost none existent
alaxton
Our internet connection has been a solid 70/20 in forever
today it is now running at 20/10
We have powered off the equipment, left it for five minutes and back on and its still the same.
Last time this happened an engineer was required and it was an external fault.
Could someone from Plusnet check it? I am unable to call at the moment. Thanks
3 REPLIES 3
Fixes: 388
Re: Internet connection almost none existent
If the phone test passes, report a broadband problem via: https://www.plus.net/help/report-a-problem/broadband/
The above assumes you still have 'normal' landline connection - if you have a SOGEA (internet only) one, just use the second link to report a network issue.
alaxton
Hi John
First issue, we don't own a phone. The line is solely used for the internet and has a pre-filtered faceplate from Openreach and only the modem is connected to it.
I will have to purchase a phone to do the line test. Funny how the issue started following the snow fall.
Once we have the phone we will perform the test, following that i guess it will be a call to Plusnet?
Fixes: 388
If you don't have a phone to test with, that is unfortunate, but not a major issue - just use the second link to report an issue.
