Internet Live Today But No Upload using Wireless
Jaggies
Re: Internet Live Today But No Upload
Is the zero upload with multiple devices? If so, it's probably a router fault.
If it's only on a single device, then a wireless card driver update may help resolve the issue, if there are any available.
caravanj
Quote from: Anotherone
Ah well done, I see you found it. No it's not over friendly, but you can do most of the basics that the average user usually wants to do through the GUI without resorting to Telnet, which is necessary when your want to have a more specialist customisation.
Anyway I got sidetracked last night, this link http://192.168.1.254/cgi/b/dsl/dt/?be=0&l0=2&l1=0 ought to take you direct to the stats (via the login screen) to be a bit quicker.
So, hmmm, longish line, never helps.
Errors are a bit high for the brief uptime, but then again your line is not Interleaved at the moment (no FEC errors) so I expect DLM will kick it in soon and turn on Interleaving which should improve that situation. Otherwise the sync speed is pretty good for the line attenuation which hopefully shows your line is essentially in pretty good nick (unless you have any intermittent iffy joints that aren't showing at present). And there's some data downloaded and uploaded, otherwise nothing there to indicate an issue. Very odd. OK try the following, but when you post up anything that may contain your IP address or other personal details,don't forget to delete them off the post.
Check which Gateway you are on
Also try http://users.plus.net/@gateway_custom?debug-ip=yes which shouldn't show your IP address unless the modem/router is responding to pings.
Have a look at the Internet connection details http://192.168.1.254/cgi/b/is/_pppoa_/ov/?be=0&l0=2&l1=2&name=Internet in the modem/router. Lots of personal detail there.
See if that lot shows up anything out of the ordinary.
Hi anotherone,
These are the readings from the two links in your above post.
The details in the internet connection details don't seem out of the normal.
You are currently connected to gateway pcl-bng02.
This is located in City Lifeline House.
Which gateway
Array
   [0] =>  1  vl50.peh-asr03.plus.net (84.92.0.73)  0.499 ms
   [1] =>  2  po3.3656.peh-cr01.plus.net (84.93.232.32)  0.529 ms
   [2] =>  3  po5.peh-cr02.plus.net (84.93.232.17)  9.996 ms
   [3] =>  4  84-93-232-60 (84.93.232.60)  9.742 ms
   [4] =>  5  ae3.ptw-cr01.plus.net (195.166.129.32)  19.173 ms
   [5] =>  6  ae1.pcl-cr01.plus.net (195.166.129.1)  11.192 ms
   [6] =>  7  irb.11.central11.pcl-bng02.plus.net (84.93.249.99)  11.339 ms
   [7] =>  8  *
   [8] =>  9  *
Anotherone
Champion
Fixes: 21
That info is fairly typical, apart from which now we know this is a wireless problem, it doesn't really help much.
You can/should always leave off the "and checking ......... from the "You are using a debugging mode" line.
If you go to http://192.168.1.254/device_tod.lp?be=0&l0=4&l1=1 you haven't perchance got anything odd set up there?
Or anywhere else in that Home Network section? (All the bits in blue are links to more detail).
caravanj
No there's nothing odd there & the access timer is disabled.
I have exactly the same setup & laptop that worked on BT, Sky & Virgin.
The only change is the Plusnet ISP & or router.
chenks76
All Star
Fixes: 12
you don't have any static IP addresses still configured from the previous networks on the other routers?
the wifi devices are definitely picking up an IP from the new router?
did you change the WIFI name on the plusnet router to match your previous WIFI network? or have you left it "as is"?
i've seen problems occur when the wifi name has been changed to match a previous network and devices get confused.
caravanj
I use the rule of "if it ain't broke don't fix it" so I moved the laptop from our old house where it was on Virgin, to our new house where it's on Plusnet.
Absolutely nothing's been changed & the router's in "out-of-the-box" condition apart from the password.
Edit: I ran the configuration wizard which changed the service name from PPOA to Plusnet after which the internet connection failed so I did another factory reset which put the service name back to PPOA.
I can now  post via wireless & VPN's working but BT Wholesale speed tester still shows 0.0meg for the upload speed whilst the USwitch speed tester shows 0.3meg upload speed.
caravanj
I spoke too soon as the problem's recurred so it worked after a factory reset, did a few uploads & then crashed again.
Anotherone
Champion
Fixes: 21
Following up on chenks thoughts (bearing in mind I'm no wifi expert, MrW is the man for that) is I have come across odd wireless behaviour before when there's been more than one wireless network involved but can't recall the detail.
Bearing in mind, your Plusnet Wireless will have its own name, either the default or something you've given it - on your laptop, go into network settings and delete any references you can find to any wireless connections. Then reboot the laptop as well. Also delete the wireless connection detail for it in the router.
Then try setting up the Plusnet one again. That may help.
caravanj
I can't even get a wireless internet connection now, it connects to the router but hangs on "identifying".
The BT Wifi-Fon connects, identifies & has an internet connection in about 5 seconds from clicking connect.
Anotherone
Champion
Fixes: 21
It is sounding like the 582n wireless is FUBAR.
Jaggies
Isn't there a known issue with that router and some wifi adaptors, which could be solved by using a wired connection, logging in to the router, and shortening the SSID?
Anotherone
Champion
Fixes: 21
Well I found a couple of odd references to this, but at the time no evidence from affected users that they did it or it worked. There's certainly no harm in trying it and then we may know  if that actually works.
Fixes: 392
You could also try disabling WiFi 'n' mode and see if it makes any difference (  instructions are here http://npr.me.uk/telnet.html )
It does sound like the router though...
caravanj
Thanks for all your replies.
Well I got an internet connection via  Plusnet  wirelessly just now & typed a reply which then, which I forgot, wouldn't upload so this is posted via BT WiFi-Fon
The Plusnet wireless internet connection issue has occurred only once, to date, whilst the non-upload & non-VPN is a constant fault.
The laptop was left on standby since last night so it's not a restart that made the difference.
I'll try the latest potential solutions & report back.
If all else fails I might get a cheapo wireless router from Maplins.
caravanj
Thanks Jaggies but shortening the SSID name didn't work but disabling WiFi 'n' mode & fixing it at 802.11b/g has worked so now I can upload via a Plusnet wireless connection so thanks for that one Mr W.
I'm still working on the VPN problem & I'll ask the VPN provider for any ideas they may have.
