Internet Live Today But No Upload using Wireless
caravanj
Our internet went live today but I can't upload anything & I'm now back to having to use the trusty old BT Wifi-Fon connection to upload this post.
The various speed checkers show our download speed as 4.5meg but most  won't even do an upload test or return a 0.0meg result.
52 REPLIES 52
AndyH
Re: Internet Live Today But No Upload
Can you post your router stats (from the router admin page)?
caravanj
I can't find where they are & the router is the least user-friendly one that I've ever had.
I've had a dreadful day trying to sort it out along with my VPN not working.
I'm tempted to just keep on using BT Wi-fi-Fon until my Plusnet contract expires & then moving elsewhere,
I've had nothing but grief since I signed up.
The router's switched off now until I decide what to do. I've got another 2 weeks with my existing BT Wi-fi-Fon connection but thanks for your offer of help anyway.
Anotherone
Champion
Fixes: 21
OMG, you're not having much luck. I was going to post a link direct to the stats, but whether it works may depend on your firmware version.
But go to the Modem/router main page 192.168.1.254 do you see a login screen?
The Username should be admin and the password is the serial number. Click OK.
On the next screen, at the top you'll see Information and it'll tell you the software release.
I'll post a bit more in a minute.
caravanj
Hi Anotherone,
The router version is 10.2.2.B if I've rembered it correctly & I've done two factory resets on it.
I've had broadband routers since 1998 on Diamond Cable, NTL, Nildram, BT, Sky & Virgin with never a problem & they were all user-controllable for all necessary functions such as disabling the firewall & allowing PPTP etc. Non of this Telnet programming garbage.
I've just sent a test email & it's gone through but if I try to post on here I just get the timed out message which is why I'm having to post this via my VPN on BT Wi-fi Fon.
caravanj
Link Information
Uptime: 0 days, 1:19:47
DSL Type: ITU-T G.992.3
Bandwidth (Up/Down) [kbps/kbps]: 1,019 / 5,403
Data Transferred (Sent/Received) [MB/MB]: 3.92 / 37.53
Output Power (Up/Down) [dBm]: 12.5 / 0.0
Line Attenuation (Up/Down) [dB]: 31.9 / 52.0
SN Margin (Up/Down) [dB]: 6.4 / 5.4
Loss of Link (Remote): -
Error Seconds (Local/Remote): 173 / 0
FEC Errors (Up/Down): 0 / 0
CRC Errors (Up/Down): 8 / 286
HEC Errors (Up/Down): 8 / 903
Anotherone
Champion
Fixes: 21
Ah well done, I see you found it. No it's not over friendly, but you can do most of the basics that the average user usually wants to do through the GUI without resorting to Telnet, which is necessary when your want to have a more specialist customisation.
Anyway I got sidetracked last night, this link http://192.168.1.254/cgi/b/dsl/dt/?be=0&l0=2&l1=0 ought to take you direct to the stats (via the login screen) to be a bit quicker.
So, hmmm, longish line, never helps.
Errors are a bit high for the brief uptime, but then again your line is not Interleaved at the moment (no FEC errors) so I expect DLM will kick it in soon and turn on Interleaving which should improve that situation. Otherwise the sync speed is pretty good for the line attenuation which hopefully shows your line is essentially in pretty good nick (unless you have any intermittent iffy joints that aren't showing at present). And there's some data downloaded and uploaded, otherwise nothing there to indicate an issue. Very odd. OK try the following, but when you post up anything that may contain your IP address or other personal details,don't forget to delete them off the post.
Check which Gateway you are on
Also try http://users.plus.net/@gateway_custom?debug-ip=yes which shouldn't show your IP address unless the modem/router is responding to pings.
Have a look at the Internet connection details http://192.168.1.254/cgi/b/is/_pppoa_/ov/?be=0&l0=2&l1=2&name=Internet in the modem/router. Lots of personal detail there.
See if that lot shows up anything out of the ordinary.
Fixes: 392
@caravanj,
Are you using a wired or wireless connection to the PlusNet router ? if it's wireless can you try a wired connection and see if the upload problems are still there.
Anotherone
Champion
Fixes: 21
I should have thought of that, a bit early in the morning today Roll_eyes thanks Ian.
caravanj
Thanks both of you, let's see if this works.
Well it has & I've got the VPN working as well by assigning PPTP from the games menu but not when it's on wireless.
We've got a new-build house & we had it cat5e cabled to every room so wireless isn't too much of a problem but I suppose I need to fix it.
P.S. the BT Wholesale speed test still shows 0.0 meg upload but the Uswitch speed checker showed 4.5 meg download & 0.31 meg upload.
Fixes: 392
The problem with wireless may well be as simple as interference from neighbouring routers. Try a wireless survey to see what other networks are around and then try changing the channel on the router to a less used one. This guide http://www.plus.net/support/broadband/hardware/technicolor-582n-wireless.shtml shows how to change wireless settings on the PN router.
a bit early in the morning today thanks Ian.
I'm already on my 2nd cup of tea so my brain's had some sustinence. Smiley
caravanj
Wireless upload test.
And again.
But not now it ain't.
Anotherone
Champion
Fixes: 21
I'm off to get a coffee and see if my brain get's untangled  Grin
chenks76
All Star
Fixes: 12
Quote from: caravanj
bear in mind that any rules you have set up will be to a device per IP address.
the IP address of a device when using ethernet will be different to that when it is connected via WIFI - thus it is technically a "new" device on the network.
caravanj
Yes, I wasn't very clear. I meant that I set up PPTP when I had a wireless connection to the router but VPN didn't work but it did as soon as I connected via ethernet.
Also I can't upload via wireless again although I can with my BT Wi-fi-Fon connection which is uses my VPN.
It has, therefore, got to be a problem with the Plusnet router set up.
As I said previously, I've never had these problems with any other ISP or router.
What a far-sighted thing it was when I got the house cat5e cabled to every room.
I use a VPN as I do my accounts & tax self-assessment online but as I have ethernet outlets in every room it'll be more secure to use those anyway.
Thanks for your help.
