Internet Going off
- Internet Going off
Internet Going off
Internet Going off
03-11-2012 8:59 PM
Re: Internet Going off
03-11-2012 9:10 PM
03-11-2012 9:29 PM
03-11-2012 11:00 PM
The first steps in the troubleshooter cover diagnostic tests to eliminate problems local to your property - it is important that these are carried out.
04-11-2012 3:20 AM
04-11-2012 7:24 AM
05-11-2012 2:32 PM
I've checked your connection and your looks like it's performing as it should. I've posted a log of your connection below;
<img src="http://ccgi.psmith12.plus.com/visradius/generated/image13521254124057.png" />
Did anything happen internally at the times, any other electrical devices on at that time, any bad weather?
If it persists then it would be worth raising a fault at http://faults.plus.net and running through the initial diagnostic questions.
Let me know how you get on.
Chris
@Fireant
Looking at your connection on Saturday it appears that you had quite a few drops, it's looks stable now.
Let me know how you're getting on.
05-11-2012 9:59 PM
05-11-2012 10:39 PM
06-11-2012 9:40 AM
As spraxyt says above, we need you to report a fault at the link in his post - unfortunately until that's done we can't investigate it because that wizard will take you through a few tests that need to be done before we can report anything.
If you could run through that wizard we'll make sure we get things sorted out for you.
10-11-2012 5:56 PM
