Internet Explorer Offline
penneck
Had a problem today with my TG582N Router - when using Internet Explorer from my main pc (desktop connected by cable), it would suddenly go to the "Router Username and Password" view. It felt rather warm, and I found that where I had moved it to a few days ago I had it laying on the ventilation holes on the underside blocking them. I turned it off, put it on supports to unblock the vents, and turned it on again after a cooling off period. It seems to be working okay now, but I have found that one of the laptops connected via the wireless network says that Internet Explorer on that particular laptop is working Offline.
Is there something I need to do to get that laptop working Online, or will it sort that problem out itself?
TORPC
Re: Internet Explorer Offline
With Internet explorer open click on Tools scroll down and Untick Work Offline
penneck
Done. Working now. Thanks
TORPC
Your welcome Smiley
