Internet Dropouts and High Ping
- Internet Dropouts and High Ping
28-04-2018 5:47 PM
Hi, recently i am getting more and more frequent disconnections from the internet, it appears to be a login issue, i don't appear to loose sync, just it logs out and back in again, it gets worse in the evenings
Also now my ping to websites is really high and gaming is almost impossible
Tracing route to bbc.co.uk [151.101.0.81]
over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms 192.168.1.1
2 * * * Request timed out.
3 * * * Request timed out.
4 297 ms * 335 ms 195.166.143.132
5 185 ms 331 ms * 195.99.125.144
6 297 ms 291 ms 313 ms 109.159.252.160
7 297 ms 280 ms 226 ms 195.99.126.81
8 * 235 ms 227 ms 151.101.0.81
Trace complete.
I am hard wired to a gigabit router
unfortunately no options of FTTC or FTTP in my area as none of the cabs at the exchange have fibre
Any ideas on getting my latency improved?
Re: Internet Dropouts and High Ping
29-04-2018 3:51 PM
Hi there.
I'm sorry to hear you're experiencing connection problems.
Our tests are finding a potential line card fault at the exchange, so I've raised this with Openreach now.
I'll update your account with more info soon, but we should know more within 1-3 working days.
Apologies for the inconvenience caused.
Anoush
10-05-2018 10:38 PM
I see the ticket has been closed, but the issue has not been resolved
I have had at least 10+ disconnect/reconnects in the last hour, so something still isn't right, seems to get worse later in the evenings
11-05-2018 12:56 PM
