Internet Disconnects
- Internet Disconnects
15-11-2012 9:19 AM
Anyone help me this mornning my internet was fine, from about 8:30 this mornning internet just goes dead when I look at the router the internet light is off and also so is the DSL ones, when it comes back on lasts for about 10 min then goes off agian. I tryed chnageing the fillters but same thing happens I live in North Wales I duno if it's my exchnage anyway any help be great thanls.
Message 1 of 4
(683 Views)
3 REPLIES 3
Re: Internet Disconnects
15-11-2012 10:41 AM
Sorry to hear that, I've run a few tests and can't see anything obvious that might cause that so I'm going to advise raising a <a href="http://faults.plus.net">fault</a> as that will advise you of some other initial checks you can do and allow you to log the issue with us for further testing and raising with our suppliers if appropriate.
Message 2 of 4
(357 Views)
15-11-2012 2:35 PM
Thnks Adam for the comment, it seemed to be ok after a while seems to be running ok now, only thing I did do is power down the rouer and put it back on, since then it been ok
Message 3 of 4
(357 Views)
15-11-2012 4:38 PM
Message 4 of 4
(357 Views)
