Internal routing problem
- Internal routing problem
02-06-2014 5:55 PM
Howdy,
There appears to be a problem with routing across gateways.
I'm trying to access my home server, which I know is up and working as I can access it from work, but it is timing out from my partner's PN connection.
This is what a traceroute shows
This is what the trace back looks like:
As you can see from the trace from my IP there are multiple responces on hops 4 and 5.
A gateway hop will probably fix this (which I'm about to attempt) but I thought I'd bring it to dave's attention.
Cheers,
A.
Tracing route to *.avatastic.co.uk [84.92.17.xxx]
over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms 192.168.1.1
2 20 ms 36 ms 20 ms lo0-central10.ptw-ag02.plus.net [195.166.128.196]
3 21 ms 20 ms 20 ms link-a-central10.ptw-gw01.plus.net [212.159.2.148]
4 19 ms 20 ms 19 ms xe-0-2-0.ptw-cr01.plus.net [212.159.0.248]
5 20 ms 39 ms 20 ms ae2.ptw-cr02.plus.net [195.166.129.5]
6 58 ms 102 ms 85 ms ae1.pcl-cr02.plus.net [195.166.129.3]
7 19 ms 31 ms 29 ms te4-5.pcl-gw02.plus.net [212.159.0.219]
8 21 ms 22 ms 21 ms link-b-central10.pcl-ag07.plus.net [212.159.2.187]
9 * * * Request timed out.
adw@skynet:~$ traceroute 146.90.65.xxx
traceroute to 146.90.65.xxx (146.90.65.xxx), 64 hops max, 52 byte packets
1 lo0-central10.pcl-ag07.plus.net (195.166.128.188) 33.405 ms 28.543 ms 27.768 ms
2 link-a-central10.pcl-gw01.plus.net (212.159.2.184) 23.541 ms 26.530 ms 25.047 ms
3 xe-9-0-0.pcl-cr01.plus.net (212.159.0.216) 24.570 ms 114.915 ms 34.954 ms
4 ae2.pcl-cr02.plus.net (195.166.129.7) 27.385 ms
ae1.ptw-cr01.plus.net (195.166.129.0) 25.176 ms 26.348 ms
5 ae1.ptw-cr02.plus.net (195.166.129.2) 24.598 ms
te8-5.ptw-gw01.plus.net (212.159.0.249) 25.402 ms 26.013 ms
6 te8-5.ptw-gw02.plus.net (212.159.0.251) 24.939 ms 27.036 ms 24.023 ms
7 link-b-central10.ptw-ag02.plus.net (212.159.2.151) 25.840 ms 27.618 ms
8 * * *
Cheers,
A.
Message 1 of 3
(732 Views)
2 REPLIES 2
Re: Internal routing problem
03-06-2014 10:28 AM
There's multiple routes across the core but they're evenly weighted so it could take any path.
PCL-CR01 is connected to PCL-CR02 and PTW-CR01 but not PTW-CR02 so to get from PCL-CR01 to PTW-CR02 it has to go via PCL-CR02 or PTW-CR01 but there's an equal chance of each route on the way out and on the way back.
Be interested to see if it gets fixed with a disconnect.
Dave Tomlinson
Plusnet Technology
Plusnet Technology
Message 2 of 3
(370 Views)
03-06-2014 4:46 PM
Hi dave,
It was fixed with a disconnect by the 146.90.65.xxx address.
If it happens again (it also happened on Friday and Saturday) I'll do a gateway hop from the 84.92.17.xxx end instead to see if that fixes it.
Message 3 of 3
(370 Views)
