Internal IP address, DHCP server issues & lack of internet connection.
- Internal IP address, DHCP server issues & lack of ...
- « Previous
- 1
- 2
- Next »
Re: Internal IP address, DHCP server issues & lack of internet connection.
01-04-2019 4:46 PM
router 1 192.168.1.254 - DHCP - no wan connections. DSL to phone line and Lan 1 runs to router 2
router 2 192.168.1.1 - no DHCP - no wan connections
I can confirm both connected via ethernet cable to LAN ports
Even if I bypass router 2 and go direct to router 1 via ethernet cable the connection still drops!
thanks
01-04-2019 4:52 PM
Are you able to disconnect all devices apart from 1 router and 1 hardwired desktop computer letting us know if you still experience the drops? This will narrow down where the issue may lie.
01-04-2019 5:00 PM
KAK!
Yeh I guess so! Currently 21 devices connected!
Will take a while when the house is quiet to do, will attempt over the next few days!
01-04-2019 5:04 PM
01-04-2019 5:30 PM
I've tested by removing the manual IP address for PC and the problem comes back - manually re-assign IP and the problem goes away.
I'm still stuck back here. If you're manually having to set an IP to connect, the DHCP can't be on, or is it, I don't know anymore!
Are these both Hub one's, or is the other a different type (Home hub etc)
I'm missing something. I don't get why you need to assign an IP for it to connect.
This sounds like router 2 is controlling your network, not router 1. I's still missing sumfink
1 x hub one. Router 2 off. Does anything connect to the hub one, either ethernet or wifi?
- « Previous
- 1
- 2
- Next »
