Intermittent wifi drop out - "Defragmentation failed"
rdl1972
Getting regular (up to 5-6 x day) drop outs on Wifi.  I've checked the connection status and the route tells me it's connected OK to the Plusnet network though.
The Event log shows mention of "packets being blocked" and "defragmentation failed"  I've listed them below for info.
Any ideas?
2.4ghz channel is set to 6 as advised
5ghz channel left on auto as advised
Thanks!
17:04:35, 02 Nov. BLOCKED 4 more packets (because of Defragmentation failed)
17:04:34, 02 Nov. IN: BLOCK [5] Fragmented packet (UDP 109.251.120.110-​>213.31.233.19 fragment_offset=0)
17:04:34, 02 Nov. IN: BLOCK [5] Fragmented packet (IP 213.237.190.18-​>213.31.233.19 fragment_offset=1480)
17:04:34, 02 Nov. IN: BLOCK [5] Fragmented packet (IP 213.237.190.18-​>213.31.233.19 fragment_offset=1472)
17:04:34, 02 Nov. IN: BLOCK [5] Fragmented packet (UDP 213.237.190.18-​>213.31.233.19 fragment_offset=0)
17:04:34, 02 Nov. IN: BLOCK [5] Fragmented packet (IP 190.4.209.58-​>213.31.233.19 fragment_offset=1480)
17:04:34, 02 Nov. IN: BLOCK [5] Fragmented packet (UDP 193.110.199.86-​>213.31.233.19 fragment_offset=0)
17:04:34, 02 Nov. IN: BLOCK [5] Fragmented packet (IP 216.17.149.169-​>213.31.233.19 fragment_offset=2960)
17:04:34, 02 Nov. IN: BLOCK [5] Fragmented packet (UDP 190.29.112.30-​>213.31.233.19 fragment_offset=0)
17:04:34, 02 Nov. IN: BLOCK [5] Fragmented packet (IP 87.103.204.3-​>213.31.233.19 fragment_offset=2912)
17:04:34, 02 Nov. IN: BLOCK [5] Fragmented packet (IP 182.53.196.126-​>213.31.233.19 fragment_offset=1456)
17:04:34, 02 Nov. IN: BLOCK [5] Fragmented packet (UDP 182.53.196.126-​>213.31.233.19 fragment_offset=0)
17:04:34, 02 Nov. IN: BLOCK [5] Fragmented packet (UDP 47.42.229.73-​>213.31.233.19 fragment_offset=0)
17:04:34, 02 Nov. IN: BLOCK [53] Defragmentation failed (Fragmented packet, packet exceeds: UDP [190.85.180.46]:53-​>[213.31.233.19]:44506 on ppp3)
17:04:34, 02 Nov. BLOCKED 1 more packets (because of Defragmentation failed)
17:04:33, 02 Nov. IN: BLOCK [53] Defragmentation failed (Fragmented packet, packet exceeds: UDP [200.164.77.98]:53-​>[213.31.233.19]:6826 on ppp3)
17:04:32, 02 Nov. BLOCKED 26 more packets (because of Defragmentation failed)
17:04:31, 02 Nov. IN: BLOCK [53] Defragmentation failed (Fragmented packet, packet exceeds: UDP Fragment 210.68.53.10-​>213.31.233.19 offset: 1480 on ppp3)
17:04:30, 02 Nov. BLOCKED 97 more packets (because of Defragmentation failed)
17:04:29, 02 Nov. IN: BLOCK [53] Defragmentation failed (Fragmented packet, packet exceeds: UDP [185.51.94.208]:53-​>[213.31.233.19]:41137 on ppp3)
17:04:29, 02 Nov. BLOCKED 101 more packets (because of Defragmentation failed)
17:04:28, 02 Nov. IN: BLOCK [53] Defragmentation failed (Fragmented packet, packet exceeds: UDP [51.77.231.89]:53-​>[213.31.233.19]:400 on ppp3)
17:04:28, 02 Nov. BLOCKED 260 more packets (because of Defragmentation failed)
17:04:27, 02 Nov. IN: BLOCK [53] Defragmentation failed (Fragmented packet, packet exceeds: UDP Fragment 209.144.50.129-​>213.31.233.19 offset: 1480 on ppp3)
17:04:27, 02 Nov. BLOCKED 5301 more packets (because of Defragmentation failed)
17:04:26, 02 Nov. IN: BLOCK [53] Defragmentation failed (Fragmented packet, packet exceeds: UDP [109.195.149.97]:53-​>[213.31.233.19]:38761 on ppp3)
17:04:26, 02 Nov. BLOCKED 8996 more packets (because of Defragmentation failed)
17:04:25, 02 Nov. IN: BLOCK [53] Defragmentation failed (Fragmented packet, packet exceeds: UDP Fragment 201.162.242.50-​>213.31.233.19 offset: 1472 on ppp3)
17:04:25, 02 Nov. BLOCKED 8998 more packets (because of Defragmentation failed)
17:04:24, 02 Nov. IN: BLOCK [53] Defragmentation failed (Fragmented packet, packet exceeds: UDP Fragment 195.46.172.190-​>213.31.233.19 offset: 1480 on ppp3)
17:04:24, 02 Nov. BLOCKED 9135 more packets (because of Defragmentation failed)
17:04:23, 02 Nov. IN: BLOCK [53] Defragmentation failed (Fragmented packet, packet exceeds: UDP [216.218.228.86]:53-​>[213.31.233.19]:61542 on ppp3)
17:04:23, 02 Nov. BLOCKED 9070 more packets (because of Defragmentation failed)
17:04:22, 02 Nov. IN: BLOCK [53] Defragmentation failed (Fragmented packet, packet exceeds: UDP Fragment 50.115.104.186-​>213.31.233.19 offset: 2960 on ppp3)
17:04:22, 02 Nov. BLOCKED 9047 more packets (because of Defragmentation failed)
17:04:21, 02 Nov. IN: BLOCK [53] Defragmentation failed (Fragmented packet, packet exceeds: UDP Fragment 169.239.171.98-​>213.31.233.19 offset: 1480 on ppp3)
17:04:21, 02 Nov. BLOCKED 8996 more packets (because of Defragmentation failed)
17:04:20, 02 Nov. IN: BLOCK [53] Defragmentation failed (Fragmented packet, packet exceeds: UDP Fragment 51.178.189.228-​>213.31.233.19 offset: 1424 on ppp3)
17:04:20, 02 Nov. BLOCKED 8903 more packets (because of Defragmentation failed)
17:04:19, 02 Nov. IN: BLOCK [53] Defragmentation failed (Fragmented packet, packet exceeds: UDP Fragment 144.76.41.158-​>213.31.233.19 offset: 2960 on ppp3)
17:04:19, 02 Nov. BLOCKED 9241 more packets (because of Defragmentation failed)
17:04:18, 02 Nov. IN: BLOCK [53] Defragmentation failed (Fragmented packet, packet exceeds: UDP Fragment 91.103.192.176-​>213.31.233.19 offset: 1480 on ppp3)
17:04:18, 02 Nov. BLOCKED 9039 more packets (because of Defragmentation failed)
17:04:17, 02 Nov. IN: BLOCK [53] Defragmentation failed (Fragmented packet, packet exceeds: UDP [185.255.46.139]:53-​>[213.31.233.19]:30708 on ppp3)
17:04:17, 02 Nov. BLOCKED 8905 more packets (because of Defragmentation failed)
17:04:16, 02 Nov. IN: BLOCK [53] Defragmentation failed (Fragmented packet, packet exceeds: UDP Fragment 179.124.129.69-​>213.31.233.19 offset: 1480 on ppp3)
17:04:16, 02 Nov. BLOCKED 8980 more packets (because of Defragmentation failed)
17:04:15, 02 Nov. IN: BLOCK [53] Defragmentation failed (Fragmented packet, packet exceeds: UDP Fragment 45.171.254.205-​>213.31.233.19 offset: 2952 on ppp3)
17:04:15, 02 Nov. BLOCKED 9017 more packets (because of Defragmentation failed)
17:04:14, 02 Nov. IN: BLOCK [53] Defragmentation failed (Fragmented packet, packet exceeds: UDP [122.252.234.114]:53-​>[213.31.233.19]:48490 on ppp3)
17:04:14, 02 Nov. BLOCKED 9075 more packets (because of Defragmentation failed)
17:04:13, 02 Nov. IN: BLOCK [53] Defragmentation failed (Fragmented packet, packet exceeds: UDP [185.108.208.252]:53-​>[213.31.233.19]:45217 on ppp3)
17:04:13, 02 Nov. BLOCKED 9092 more packets (because of Defragmentation failed)
17:04:12, 02 Nov. IN: BLOCK [53] Defragmentation failed (Fragmented packet, packet exceeds: UDP Fragment 151.236.35.6-​>213.31.233.19 offset: 2960 on ppp3)
17:04:12, 02 Nov. BLOCKED 8959 more packets (because of Defragmentation failed)
17:04:11, 02 Nov. IN: BLOCK [53] Defragmentation failed (Fragmented packet, packet exceeds: UDP [185.60.44.106]:53-​>[213.31.233.19]:14309 on ppp3)
17:04:11, 02 Nov. BLOCKED 9018 more packets (because of Defragmentation failed)
17:04:10, 02 Nov. IN: BLOCK [53] Defragmentation failed (Fragmented packet, packet exceeds: UDP Fragment 38.140.42.188-​>213.31.233.19 offset: 2952 on ppp3)
17:04:10, 02 Nov. BLOCKED 9039 more packets (because of Defragmentation failed)
17:04:09, 02 Nov. IN: BLOCK [53] Defragmentation failed (Fragmented packet, packet exceeds: UDP Fragment 103.29.91.54-​>213.31.233.19 offset: 1472 on ppp3)
17:04:09, 02 Nov. BLOCKED 9113 more packets (because of Defragmentation failed)
17:04:08, 02 Nov. IN: BLOCK [53] Defragmentation failed (Fragmented packet, packet exceeds: UDP Fragment 212.32.213.146-​>213.31.233.19 offset: 1480 on ppp3)
17:04:08, 02 Nov. BLOCKED 9034 more packets (because of Defragmentation failed)
17:04:07, 02 Nov. IN: BLOCK [53] Defragmentation failed (Fragmented packet, packet exceeds: UDP [182.52.50.12]:53-​>[213.31.233.19]:34728 on ppp3)
17:04:07, 02 Nov. BLOCKED 9048 more packets (because of Defragmentation failed)
17:04:06, 02 Nov. IN: BLOCK [53] Defragmentation failed (Fragmented packet, packet exceeds: UDP [201.46.22.93]:53-​>[213.31.233.19]:18784 on ppp3)
17:04:06, 02 Nov. BLOCKED 9138 more packets (because of Defragmentation failed)
17:04:05, 02 Nov. IN: BLOCK [53] Defragmentation failed (Fragmented packet, packet exceeds: UDP [177.84.216.20]:53-​>[213.31.233.19]:27206 on ppp3)
17:04:05, 02 Nov. BLOCKED 8898 more packets (because of Defragmentation failed)
17:04:04, 02 Nov. IN: BLOCK [53] Defragmentation failed (Fragmented packet, packet exceeds: UDP [200.53.28.11]:53-​>[213.31.233.19]:22043 on ppp3)
17:04:04, 02 Nov. BLOCKED 9049 more packets (because of Defragmentation failed)
17:04:03, 02 Nov. IN: BLOCK [5] Fragmented packet (IP 91.122.218.180-​>213.31.233.19 fragment_offset=1456)
17:04:03, 02 Nov. IN: BLOCK [5] Fragmented packet (IP 84.21.145.74-​>213.31.233.19 fragment_offset=2960)
17:04:03, 02 Nov. IN: BLOCK [5] Fragmented packet (IP 84.21.145.74-​>213.31.233.19 fragment_offset=2952)
17:04:03, 02 Nov. IN: BLOCK [5] Fragmented packet (IP 84.21.145.74-​>213.31.233.19 fragment_offset=1480)
17:04:03, 02 Nov. IN: BLOCK [5] Fragmented packet (UDP 85.236.4.158-​>213.31.233.19 fragment_offset=0)
17:04:03, 02 Nov. IN: BLOCK [5] Fragmented packet (IP 103.148.100.140-​>213.31.233.19 fragment_offset=2960)
17:04:03, 02 Nov. IN: BLOCK [5] Fragmented packet (IP 103.148.100.140-​>213.31.233.19 fragment_offset=2952)
17:04:03, 02 Nov. IN: BLOCK [5] Fragmented packet (IP 103.148.100.140-​>213.31.233.19 fragment_offset=1480)
17:04:03, 02 Nov. IN: BLOCK [5] Fragmented packet (UDP 103.148.100.140-​>213.31.233.19 fragment_offset=0)
17:04:03, 02 Nov. IN: BLOCK [5] Fragmented packet (IP 186.103.217.234-​>213.31.233.19 fragment_offset=2960)
17:04:03, 02 Nov. IN: BLOCK [5] Fragmented packet (UDP 186.103.217.234-​>213.31.233.19 fragment_offset=0)
17:04:03, 02 Nov. IN: BLOCK [5] Fragmented packet (IP 194.8.129.129-​>213.31.233.19 fragment_offset=2960)
17:04:03, 02 Nov. IN: BLOCK [5] Fragmented packet (IP 190.85.209.186-​>213.31.233.19 fragment_offset=2960)
17:04:03, 02 Nov. IN: BLOCK [5] Fragmented packet (IP 190.85.209.186-​>213.31.233.19 fragment_offset=2952)
17:04:03, 02 Nov. IN: BLOCK [5] Fragmented packet (IP 190.85.209.186-​>213.31.233.19 fragment_offset=1480)
17:04:03, 02 Nov. IN: BLOCK [5] Fragmented packet (UDP 217.197.236.66-​>213.31.233.19 fragment_offset=0)
17:04:03, 02 Nov. IN: BLOCK [5] Fragmented packet (UDP 105.27.199.178-​>213.31.233.19 fragment_offset=0)
17:04:03, 02 Nov. IN: BLOCK [5] Fragmented packet (IP 91.230.154.42-​>213.31.233.19 fragment_offset=2960)
17:04:03, 02 Nov. IN: BLOCK [53] Defragmentation failed (Fragmented packet, packet exceeds: UDP Fragment 91.144.186.190-​>213.31.233.19 offset: 1456 on ppp3)
17:04:03, 02 Nov. BLOCKED 9124 more packets (because of Defragmentation failed)
17:04:02, 02 Nov. IN: BLOCK [53] Defragmentation failed (Fragmented packet, packet exceeds: UDP Fragment 92.246.205.99-​>213.31.233.19 offset: 1480 on ppp3)
17:04:02, 02 Nov. BLOCKED 9124 more packets (because of Defragmentation failed)
17:04:01, 02 Nov. IN: BLOCK [53] Defragmentation failed (Fragmented packet, packet exceeds: UDP Fragment 187.157.140.178-​>213.31.233.19 offset: 2960 on ppp3)
17:04:01, 02 Nov. BLOCKED 8993 more packets (because of Defragmentation failed)
17:04:00, 02 Nov. IN: BLOCK [53] Defragmentation failed (Fragmented packet, packet exceeds: UDP [180.250.124.130]:53-​>[213.31.233.19]:48439 on ppp3)
17:04:00, 02 Nov. BLOCKED 9326 more packets (because of Defragmentation failed)
17:03:59, 02 Nov. IN: BLOCK [53] Defragmentation failed (Fragmented packet, packet exceeds: UDP [93.171.9.254]:53-​>[213.31.233.19]:64308 on ppp3)
17:03:59, 02 Nov. BLOCKED 8981 more packets (because of Defragmentation failed)
Moderator's note by Mike (Mav): Post released from Spam Filter.
2 REPLIES 2
RealAleMadrid
Aspiring Hero
Fixes: 48
Re: Intermittent wifi drop out - "Defragmentation failed"
@rdl1972  The BLOCK events are the router firewall stopping attempts to access the router from the internet and are quite normal.
Your troubles are more likely due to the various wi-fi problems that the Hub one exhibits. Have a look in the router section of the forum. The link below is the massive thread about 5Ghz problems for which some test firmwares have been sent out if you ask.
https://community.plus.net/t5/My-Router/Hub-One-5GHz-WiFi-issue/td-p/1696363
There are other faults relating to reduced speed on 5GHz and some DNS problem which are known and will be fixed in a future firmware release, when that might be who knows.🙄
I have never used ISP supplied equipment and the endless problems with the Hub 1 which is actually a rehash of the old BT hub 5A justifies my decision. However the BT Hub 6 is much better, many Plusnet customers use one.
rdl1972
Thanks for your help @RealAleMadrid
I'm having no luck with the router at all so am going to try just using it as a modem and running the wifi through a couple of Google Nest routers.
I've checked out the posts from people who have managed to do this with a Plusnet One so fingers crossed I won't lose what hair I have left setting it up Smiley
