Intermittent very slow speeds
- Intermittent very slow speeds
Re: Intermittent very slow speeds
24-08-2009 12:29 PM
24-08-2009 1:55 PM
24-08-2009 6:36 PM
It's now about 65 hours at this speed. I thought I'd at least see some kind of improvement by now even if not full speed.
24-08-2009 8:15 PM
Hopefully if the connection remains stable, you should see an improvement in the next 24 hours.
25-08-2009 5:53 PM
My router is showing 49:30 hours up. Can someone confirm that this is correct from PN's point of view?
26-08-2009 6:58 AM
26-08-2009 3:49 PM
It looks like it changed at 10:45am today.
29-08-2009 7:30 AM
Router logs:
Sat, 2009-08-29 03:46:30 - LCP down.
Sat, 2009-08-29 03:46:42 - Initialize LCP.
Sat, 2009-08-29 03:46:42 - LCP is allowed to come up.
Sat, 2009-08-29 03:47:42 - Initialize LCP.
Sat, 2009-08-29 03:47:42 - LCP is allowed to come up.
Sat, 2009-08-29 03:47:52 - CHAP authentication success
Sat, 2009-08-29 03:51:02 - LCP down.
Sat, 2009-08-29 03:51:09 - Initialize LCP.
Sat, 2009-08-29 03:51:09 - LCP is allowed to come up.
Sat, 2009-08-29 03:51:13 - CHAP authentication success
Sat, 2009-08-29 06:16:35 - Administrator login successful - IP:192.168.0.66
Sat, 2009-08-29 06:17:00 - LCP down.
Sat, 2009-08-29 06:17:10 - Initialize LCP.
Sat, 2009-08-29 06:17:10 - LCP is allowed to come up.
Sat, 2009-08-29 06:17:14 - CHAP authentication success
BT Speedtest:
Test1 comprises of Best Effort Test: -provides background information.
Your DSL connection rate: 2016 kbps(DOWN-STREAM), 448 kbps(UP-STREAM)
IP profile for your line is - 135 kbps
Actual IP throughput achieved during the test was - 84 kbps
I am using a short cable to the socket. I am plugged into the master socket. I have got a microfilter and I have not got a phone attached (which is upsetting people since I am currently planning my dad's funeral on Thursday and noone can contact me).
I am getting extremely upset by this service. I am paying £16 per month and basically not getting the service no matter what I try to do. I have just paid out for another month of World of Warcraft and I cannot use it since I cannot connect. I cannot use my xbox. I cannot sort out the stuff I'm trying to do online for my dad. This is an appalling service and I'm getting no help. This has been going on for months now.
29-08-2009 9:12 AM
29-08-2009 10:58 AM
I already have a support ticket but only James and Mand seem to read it.
29-08-2009 12:03 PM
[Moderator's note by Jim (Oldjim) Agents name removed ]
EDIT: Sorry, didn't realise that wasn't allowed.
29-08-2009 2:18 PM
29-08-2009 3:26 PM
Anyway,
I came home just now to find there was a dropped connection while I was out and my router log says:
Sat, 2009-08-29 13:40:33 - TCP Packet - Source:190.84.214.65,3033 Destination:"One of my home PC IPs Removed" - [DCC match] <-- "DCC is because of a match with my router's firewall settings
Sat, 2009-08-29 13:41:07 - Initialize LCP.
Sat, 2009-08-29 13:41:07 - LCP is allowed to come up.
Sat, 2009-08-29 13:41:11 - CHAP authentication success
So what was that packet that was sent? I was out and all my computers were off but that packet seems to cause a dropped connection. There isn't a log message that the LCP went down though, just that it was initialised and allowed to come up.
29-08-2009 3:31 PM
3 33 ms 33 ms 33 ms gi1-6-604.pcl-gw02.plus.net [84.92.0.229]
4 33 ms 35 ms 33 ms te2-1.pcl-gw01.plus.net [212.159.1.113]
5 33 ms 32 ms 32 ms xe-1-2-0-0.lon20.ip4.tinet.net [213.200.79.233]
6 47 ms 33 ms 32 ms xe-8-1-0.lon10.ip4.tinet.net [89.149.185.238]
7 36 ms 35 ms 34 ms as6453.ip4.tinet.net [77.67.66.22]
8 32 ms 32 ms 33 ms if-4-1-0-463.mcore3.LDN-London.as6453.net [195.2
19.195.37]
9 112 ms 111 ms 113 ms if-0-0-0-841.core3.AEQ-Ashburn.as6453.net [195.2
19.195.122]
10 116 ms 111 ms 120 ms Vlan74.icore1.AEQ-Ashburn.as6453.net [216.6.51.4
2]
11 150 ms 142 ms * Vlan424.icore1.MLN-Miami.as6453.net [66.110.9.13
12 138 ms 139 ms 139 ms ix-6-0.icore1.MLN-Miami.as6453.net [66.110.9.22]
13 180 ms 179 ms 179 ms customer-187-141-106-253-sta.uninet-ide.com.mx [
187.141.106.253]
14 * * * Request timed out.
15 193 ms 193 ms 194 ms 200.26.135.202
16 194 ms 193 ms 195 ms Static-IP-cr200118389.cable.net.co [200.118.3.89
17 * * * Request timed out.
18 * * * Request timed out.
19 * * * Request timed out.
20 * *
So what is that about? Could it be that causing my drops? If not then why did I get a drop 30 seconds after it? Seems odd. I didn't notice a similar thing in the logs for the other drops so it could be a coincidence.
29-08-2009 3:47 PM
