Intermittent speed problems over past few weeks - huge ping and jitter
- Intermittent speed problems over past few weeks - ...
- « Previous
- 1
- 2
- Next »
Re: Intermittent speed problems over past few weeks - huge ping and jitter
10-11-2015 8:36 PM
Have already tried another microfilter unfortunately, as well as a different router, and no extension wiring - think I'll have to call them, that questionnaire is pretty frustrating.
Also the line stats from the other router are here:
11-11-2015 9:13 AM
Quote Have already tried another microfilter unfortunately, as well as a different router, and no extension wiring - think I'll have to call them, that questionnaire is pretty frustrating.
I'm going to be honest and say even if you called you'd be asked to do exactly the same tests. The reasoning behind it is that if the fault gets to an engineer visit and the fault is caused by the internal wiring/sockets then an engineers charge would likely be applied.
Quote I can't check to see if the line is clear by phone because we don't have a phone
Do you know anyone you could borrow a handset off for a short while to test?
12-11-2015 7:19 PM
Did you get this resolved?
I'm still seeing large spikes in connectivity.
ping google.com
Pinging google.com [212.56.71.99] with 32 bytes of data:
Reply from 212.56.71.99: bytes=32 time=842ms TTL=61
Reply from 212.56.71.99: bytes=32 time=1219ms TTL=61
Reply from 212.56.71.99: bytes=32 time=1181ms TTL=61
Reply from 212.56.71.99: bytes=32 time=1207ms TTL=61
Ping statistics for 212.56.71.99:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 842ms, Maximum = 1219ms, Average = 1112ms
13-11-2015 5:38 AM
15-11-2015 12:59 PM
Quote from: spleenharvester Spoke too soon, finally grabbed one:
Just occurred to me, is my noise margin not way too low here?
16-11-2015 2:48 PM
If it happens again try stopping anything uploading and test again.
17-11-2015 9:28 AM
19-11-2015 3:23 PM
As an aside are you using Win10 quite a few members that use it seem to have these mysterious uploads.
19-11-2015 4:17 PM
25-11-2015 10:15 PM
Someone does use skype a lot (when he's in), so given our connection is 1mbit up, that probably doesn't help. There are two others aside from me living here.
03-12-2015 4:37 AM
03-12-2015 8:21 AM
03-12-2015 11:19 AM
Quote from: spleenharvester Did any of the others in this thread have any luck?
I
'm pretty sure in my case this relates to upload. I can reproduce the fault at will by maxing out the upload, not difficult on my 20CN Max with only a 448K upload sync. In tests I can fix that by prioritising small packets, so that pings and dns and tcp acks jump the queue and aren't held up by the large upload packets.
However there are episodes where the same latency is triggered by uploads of only 200K (bits per second) or once at only 95K. These have to be problems at the service provider end - Plusnet's gateways again? Or exchange or backhaul congestion. In either case QoS on the premises doesn't help of course.
- « Previous
- 1
- 2
- Next »
