Intermittent connection
cblower1980
For the last 2 weeks I have been having regular disconnections, mostly in the evening. The ADSL light flashes rapidly and I lose all connection. If I try a reset, that works for 10-30 mins then the fault reoccurs. I have been trying to report a phone line fault as there was noise on the line, this has now cleared and I am still getting regular disconnects. Please can anyone help?
Fixes: 162
Re: Intermittent connection
Testing your line is showing a lot of disconnects:
 However a line test isn't showing any obvious issues:
  Upstream DSL Link Information Downstream DSL Link Information
Loop Loss: 17.0 33.5
SNR Margin: 15.0 9.1
Errored Seconds: 0 7
HEC Errors: 0
Cell Count: 8533 11236
Speed: 440 11570
Maximum Stable Rate (KBPS): 12480 Fault Threshold Rate (KBPS): 9984
Mean Time Between Retrains (Seconds): 3860 Mean Time Between Errors Upstream (Seconds): 11580
Indicative Line Quality: R Mean Time Between Errors Downstream (Seconds): 59
Custom
Is the router in the master socket? Has the noise completely gone now?
 Chris Parr
 Plusnet Staff
cblower1980
I can't seem to see a master socket behind either if the sockets (pic attached), the noise has completely gone. It seems to be working for longer after each reset, maybe the router is on its way out?
pvmb
That is a simple extension socket. If the other one is the same then there must be another socket or Network Terminating Equipment somewhere. Near where the Openreach network cable enters your premises.
