Intermittent Lock ups
- Re: Intermittent Lock ups
01-05-2019 11:34 AM
For some weeks now I've been suffering from intermittent issues. At some point during the day it's as if the connection has died.
Looking at my router, it suggests that the connection is still live, but nothing is coming down the pipe. Rebooting the router/modem cures it. (I've tried two different devices too).
It's just happened again (screen grab attached).
I've no idea where to start investigating this. Has anyone got any suggestions please?
01-05-2019 1:10 PM
Hi @McTed
Thanks for getting in touch.
I've taken a look at the history of your connection and can see that (as you've alluded to) the physical connection to the exchange is fine.
Can you confirm whether these "dead periods" are experienced via wifi and/or a wired connection?
Based on what you've described, this sounds like a wifi issue, but would be interested to know if this also occurs on a wired device.
Just out of interest, could you confirm which router you're currently using to connect to the Internet?
Best wishes
Dave
01-05-2019 2:49 PM
Hi Dave,
That's useful to know, thanks.
I experience it with both wired and wireless connections.
My router is a Draytek 2820 but I was getting the same with an older NetGear device that I substituted to test it.
As in the status page I uploaded, it just slows down to an RX rate of something tiny - rather than being MB per seconds, it seems to be an absolute trickle to the point where nothing will function. Rebooting the connection clears it every time.
Thanks,
Ted
01-05-2019 4:35 PM
