Intermittent High Pings
- Intermittent High Pings
- « Previous
- 1
- 2
- Next »
Re: Intermittent High Pings
14-09-2013 12:54 PM
I had to reboot the router sometime between midnight and 02:00 last night because the SNR had gone negative (the synch speed at that time was about 5.7Mb) and I was getting intermittent time-outs on pings to Plusnet.
I re-connected at 4.3Mb and it cleared that problem. I now see that the connection dropped again at about 05:30 today, although the synch speed seemes to be the same.
Message 16 of 23
(315 Views)
16-09-2013 2:56 PM
Hi thejudge,
Is your issue the same as Yaroze's? There's more detail on his thread here: http://community.plus.net/forum/index.php/topic,118272.msg1024546.html#msg1024546
If it is the same thing (certainly looks like it, though Yaroze's seems to have a cause - not sure if you've noticed anything like that?) could you please do a wireshark capture as per the post I've linked to? We'll be able to see what's up there and also check on the similarities between these two issues as well.
Message 17 of 23
(315 Views)
16-09-2013 9:09 PM
I'll give it a go, but the problem hasn't manifested itself for a couple of days now (although pings are still in the 40-50ms range rather than 30-35ms).
Message 18 of 23
(315 Views)
17-09-2013 6:34 PM
I tried raising a question because the pings are still in the 40-60ms range, but it won't let me attach the zipped Wireshark capture because it says it can't accept the file type.
Message 19 of 23
(315 Views)
17-09-2013 6:58 PM
Have you tried adding a .zip file to your ticket? They are allowed even though the hint suggests otherwise.
Is the zipped file under the 4MB limit?
David
Message 20 of 23
(315 Views)
17-09-2013 9:07 PM
It's a .gz file (Wireshark gives the option of saving the capture in that format) and is only 727Kb.
Message 21 of 23
(315 Views)
17-09-2013 10:26 PM
I think the system only accepts zip, so probably best to save as normal then zip it. Silly system, I remember thinking the first time I did it. Maybe I even typed that into the ticket!
Message 22 of 23
(315 Views)
18-09-2013 10:05 AM
It would need to be a .zip file.
Message 23 of 23
(315 Views)
- « Previous
- 1
- 2
- Next »
