Intermitent Connection
- Intermitent Connection
on
10-12-2018
6:42 PM
- last edited on
11-12-2018
8:03 AM
by
Mine too. Tried selecting a unique channel - still drops our
tried disconnecting all devices - still drops out
tried swapping router - still drops out
tried moving away from DECT phone and microwave -still drops out
tested line - and it is fine
started about 6 weeks ago - previous 4 years all Plusnet - no problem. Seem to coincide with getting an Alexa but disconnecting her doesn't stop the wifi dropping out.
wired connections work OK until router reboots itself
Moderator's note by Adie (Dvorak) adjusted topic title after split.
help please?
Re: intermitent Connection
10-12-2018 7:04 PM
@Carpenterstatio Not being funny - but 'me too' posts' don't help - please start your own topic, it is so much easier for all concerned and avoids mixing two possibly unrelated incidents.
10-12-2018 7:10 PM
Apologies Jab1 new to this medium myself having exhausted other options.
about 5 or 6 weeks ago our previously reliable wifi started dropping out intermittently. Wired connections were OK until the router rebooted itself.
we have a long house 3 wifi connections, and a wired network supported by a dell power connect unmanaged switch. Probably 40 devices connected one way or another.
We have tried every combination possible to try to isolate the culprit - but no matter what we do, the wifi keeps dropping out. This seems like the Same issue you were responding to in the last few hours (hence the "me too" comment)
10-12-2018 7:16 PM
OK @Carpenterstatio But it so much easier for those of us trying to help, if people start their own topics, and to be honest yours sounds similar, but much more complicated than @ThreeNineteen's
I might see if the mods can split your posts out tomorrow.
11-12-2018 8:01 AM
Moderators Note
This topic has been split from another thread to help support and for better visibility
Re: Intermitent Connection
11-12-2018 2:23 PM
The connection does seem to have started dropping out more frequently again (as shown in the logs I've included below) so it would be a good idea to report a fault with us next, that can be done online at http://faults.plus.net
11-12-2018 6:01 PM
Adam - we have already reported this fault to you.
plusnet made several suggestions -all of which we had already tried and plusnet have now indicated that there is nothing more you can do.
but the internet keeps dropping out. (It just has again half way through writing this post)
11-12-2018 6:03 PM
But I will report the fault again
11-12-2018 7:22 PM
Noise margin 8.9 / 11.9 if that helps?
12-12-2018 11:33 AM
Hi @Carpenterstatio,
Thank you for reporting this via the online fault portal and for running through the troubleshooting checks on your side. I'm sorry for any inconvenience that this dropping connection issue is causing you.
As our tests aren't picking up the cause of this problem, we'll need to arrange an engineer visit so that this may be investigated further. Please can you reply to the ticket here with your availability for an engineer? If you send us another message on here once you've done this, we'll pick this back up and get your appointment booked in for the earliest available suitable slot.
14-12-2018 5:41 PM
I managed to close question #185472951 by mistake. Can you reopen please?
14-12-2018 6:45 PM
We've re-opened the ticket as per your request.
Please let us know anything else in the meantime.
15-12-2018 10:43 AM
16-12-2018 11:32 AM
22-12-2018 5:05 PM
The engineer called yesterday. Replaced the BT socket, couldn't find any issues with our setup swapped over some wires.but the problem remains. Multiple drop outs again today.
Any ideas?
