Interleaving?
- Interleaving?
- « Previous
- Next »
Re: Interleaving?
20-06-2013 2:00 PM
Re: Interleaving?
20-06-2013 7:24 PM
Just to clarify a bad router wouldn't stop the modem connecting would it?
Re: Interleaving?
20-06-2013 11:06 PM
Don't worry, we'll keep on top of things for you and let you know once we've got more information.
Re: Interleaving?
21-06-2013 11:06 AM
Will moving me to 80/20 help? E.g if im on 40 now and DLM slowed me to 12. Will being put on 80 slow me to 52 for example? (Assuming my line can handle 80)
Re: Interleaving?
21-06-2013 11:41 AM
The difference between 40/10 and 80/20 is purely the upper limit.
Once you get the connection drop issue sorted you might just get the maximum speed for 40/10 (though the figures posted so far suggest possibly not), only then would a change to 80/20 be of any benefit.
Re: Interleaving?
21-06-2013 12:16 PM
Re: Interleaving?
22-06-2013 10:36 AM
Re: Interleaving?
23-06-2013 8:38 PM
Re: Interleaving?
24-06-2013 11:26 AM
Re: Interleaving?
24-06-2013 4:45 PM
- « Previous
- Next »
