Interleaving?
- Interleaving?
Interleaving?
10-06-2013 12:45 PM
and after the engineer had been out Interleaving was low?
First test results:
Test Outcome Pass
Main Fault Location OK
Sync Status In Sync
Downstream Speed 15.0 Mbps
Upstream Speed 5.0 Mbps
Appointment Required N
Fault Target Fix Time
Fault Report Advised N
Profile Name 7.5M-15M Downstream, Interleaving High - 2.5M-5M Upstream, Interleaving On
Time Stamp NA
After the engineer visit:
Engineers notes : **RAend line test ok on ecli pse and ADSL VDSL te st also Pq test done to a pass,no issues found so reset the DLM now connecting a t 39476 Mbps down an d 7402 Mbps Up which is way above the pr edicted speeds,T&D t o mrs White and advi sed.
Test Outcome Pass
Sync Status In Sync
Downstream Speed 35.8 Mbps
Upstream Speed 6.9 Mbps
Profile Name 20M-40M Downstream, Interleaving Low - 4.2M-8.5M Upstream, Interleaving On
Time Stamp 2013-06-07T05:00:00
What is the interleaving bit? Also what is the DLM that the engineer re-set? I am still having the occasional dropout since the engineer visit. Could this be a router issue?
Re: Interleaving?
10-06-2013 1:31 PM
Quote from: Olifran What is the interleaving bit?
Interleaving is error correction, basically. If any of the data that's transmitted to you is corrupted for any reason interleaving means that it's minimised and can be recovered without the computer having to request that the corrupted data is set again from the server it got it from. It does increase ping times though, but that's usually only an issue for those who play a lot of online games.
Quote from: Olifran Also what is the DLM that the engineer re-set?
DLM is Dynamic Line Management - basically an adaptive system at the exchange or in the case of FTTC the green box that adjusts the line to the ideal compromise of speed and stability. A slower line is more stable and less susceptible to errors, and vice versa.
Quote from: Olifran I am still having the occasional dropout since the engineer visit. Could this be a router issue?
It's more likely that your line can't actually handle the speed it's been set to at the moment and that's why the connection is dropping. The DLM system will adjust the line though and should slow it down just enough to stop the drops, at least that's what it's meant to do. Sometimes though it's a little over zealous.
Hope that helps explain.
Re: Interleaving?
10-06-2013 2:50 PM
Re: Interleaving?
10-06-2013 3:22 PM
<img src="http://ccgi.psmith12.plus.com/visradius/generated/image13708740448993.png"/>
This will cause the DLM to adjust the settings on your line.
Do you notice any interference or crackling on your phone line when using it?
Re: Interleaving?
10-06-2013 4:07 PM
Re: Interleaving?
10-06-2013 4:25 PM
Re: Interleaving?
10-06-2013 10:21 PM
Re: Interleaving?
11-06-2013 9:35 AM
<img src="http://ccgi.psmith12.plus.com/visradius/generated/image13709396924014.png"/>
Re: Interleaving?
11-06-2013 10:44 AM
Any ideas about the drops? Quiet line test seemed ok last night.
By the way can plusnet re set the DLM or is it an OR engineer that has to do it?
Re: Interleaving?
11-06-2013 1:06 PM
Re: Interleaving?
12-06-2013 1:02 PM
What does this mean on my ticket?
GEA fail, DCN, low sync
New Fault ID 1-16401657828 in hands with BTW now
11/06/2013 11:28 - Comment added by supplier: Designing Solution
Note: Your trouble ticket has been linked with a known incident, and we are working on a resolution
Re: Interleaving?
12-06-2013 1:52 PM
The DCN is referring to your drops in connection that you're experiencing, this is causing you to have a lower sync speed.
We're waiting for an update on the fault raised.
Re: Interleaving?
12-06-2013 4:01 PM
But said it was live so couldnt do anything, then he went underground. He was here for two hours and yes i guessed it,he re-set the DLM and something about a Triage Team who are specialist in FTTC?
So for the moment i am back up to speed , however I am expecting it to drop within a few days as the engineer has not fixed anything
Re: Interleaving?
13-06-2013 8:38 PM
Chris.
Re: Interleaving?
14-06-2013 10:09 AM
Our faults team will be checking over the engineer notes and following this up. There'll update you as soon as they have further news.
