Interleaving
- Interleaving
Interleaving
01-01-2013 9:44 AM
This morning I received an email from PN Support saying that they had requested that interleaving be turned off at my request.
Why does this upgrade trigger this request and is it neccessary?
Re: Interleaving
01-01-2013 9:51 AM
Re: Interleaving
01-01-2013 10:28 AM
No detrimental effect has been experienced, in fact, my BT Speed Test has slightly improved.
If my interleaving is switched off, I felt I'd leave it like that.
Are you saying, Old Jim, that in fact nothing has actually happened and any improvement in my connection is imagined?
How do I obtain my Connection History that I see on some Forum strings? The display that shows disconnections.....
Regards.....
Re: Interleaving
01-01-2013 10:40 AM
This is from mine - I removed a few irrelevant entries
Mon, 2012-12-24 09:50:42 - LCP down.
Mon, 2012-12-24 09:50:49 - Initialize LCP.
Mon, 2012-12-24 09:50:49 - LCP is allowed to come up.
Mon, 2012-12-24 09:50:53 - CHAP authentication success
Mon, 2012-12-31 06:37:15 - LCP down.
Mon, 2012-12-31 06:37:23 - Initialize LCP.
Mon, 2012-12-31 06:37:23 - LCP is allowed to come up.
Mon, 2012-12-31 06:38:23 - Initialize LCP.
Mon, 2012-12-31 06:38:23 - LCP is allowed to come up.
Mon, 2012-12-31 06:38:24 - CHAP authentication success
Mon, 2012-12-31 09:54:24 - LCP down.
Mon, 2012-12-31 09:54:31 - Initialize LCP.
Mon, 2012-12-31 09:54:31 - LCP is allowed to come up.
Mon, 2012-12-31 09:55:31 - Initialize LCP.
Mon, 2012-12-31 09:55:31 - LCP is allowed to come up.
Mon, 2012-12-31 09:56:31 - Initialize LCP.
Mon, 2012-12-31 09:56:31 - LCP is allowed to come up.
Mon, 2012-12-31 09:57:31 - Initialize LCP.
Mon, 2012-12-31 09:57:32 - LCP is allowed to come up.
Mon, 2012-12-31 09:58:32 - Initialize LCP.
Mon, 2012-12-31 09:58:32 - LCP is allowed to come up.
Mon, 2012-12-31 09:58:36 - CHAP authentication success
Re: Interleaving
01-01-2013 1:02 PM
I cannot understand the entries and notice that there appears to be a time-out associated with a Firewall entry....don't know what that means, either!
Regards....
Re: Interleaving
01-01-2013 1:03 PM
I never requested that interleaving should be turned off so what is going on? I am on ADSL2
Re: Interleaving
01-01-2013 1:16 PM
Re: Interleaving
01-01-2013 2:07 PM
Quote from: Oldjim Nothing happens - it is a system screw up
About time it was unscrewed then
Re: Interleaving
01-01-2013 6:39 PM
Quote from: Oldjim It needs to be requested from the staff on here - does your router log give any indications
Modify
« Reply #4 on Today at 13:02 »
Many thanks, Old Jim. The event log from my router is attached.
Regards....
Re: Interleaving
01-01-2013 8:12 PM
, that should cut down on some of the entries
http://community.plus.net/forum/index.php/topic,109764.msg939938.html#msg939938
sntp config poll=1440
saveall
Re: Interleaving
01-01-2013 10:03 PM
I guess this might make the Router log a bit more meaningful, with entries over a longer period and perhaps help to resolve my original response to Old Jim.
Regards and thanks again....Noel
Re: Interleaving
01-01-2013 10:54 PM
Re: Interleaving
02-01-2013 8:00 AM
Good to know the ".....time exceeded...." entry is "according to plan!"
Regards.....Noel
