Interleaving
- Interleaving
Interleaving
28-10-2012 11:34 PM
Message 1 of 5
(737 Views)
4 REPLIES 4
Re: Interleaving
28-10-2012 11:39 PM
Speedtest.net ping times are not always accurate.
Distance from London (where Plusnet datacentre's are located) can make quite a difference (routing to London to be a bit more precise / pedantic), distance to local exchange doesn't affect ping very much.
What do you get if you type 'ping bbc.co.uk' in a command prompt?
Call me 'w23'
Message 2 of 5
(293 Views)
Re: Interleaving
28-10-2012 11:48 PM
Message 3 of 5
(293 Views)
Re: Interleaving
28-10-2012 11:58 PM
Screenshot a bit difficult to read (ctrl+ helps a lot though).
14ms not too bad
14ms not too bad
Call me 'w23'
Message 4 of 5
(293 Views)
Re: Interleaving
29-10-2012 12:05 AM
ctrl + good one ya learn something everyday cheers , was just wondering why speeds went up with interleaving off not just pings go down .
Message 5 of 5
(293 Views)
