Interleaving
jockwav
Interleaving
Can any of the staff tell me if i am on interleaving & if so could it be turned off as that might be part of the problem.
My noise seems a little high as well,Noise Margin (Downstream)    17.0 db  so could someone look at this for me Huh
https://www.flickr.com/photos/james_bingham/
Re: Interleaving
Your routers web page should tell you that, look for Fastpath/interleaving in the overview/summary page
Unvalued customer since 2001 funding cheap internet for others / DSL/Fibre house move 24 month regrade from 8th May 2017
jockwav
Re: Interleaving
Well i would still like plusnet to check these things out as above.
Re: Interleaving
Hi Jockwav,
I have checked your connection, interleaving is currently turned on. Your line has been very stable so we can try and turn it off. If your line starts to become unstable it may be that you would need to have it turned back on, but we can monitor it and see how it goes.
I will also reset your line as the noise does appear to have spiked at a higher db. This will take up-to 24 hours to take effect.
If there's anything else then just ask.
Chris
jockwav
Re: Interleaving
Thanks very much Chris. Grin
jockwav
Re: Interleaving
Looking better already. Grin
Re: Interleaving
Good to see, let me know if there's anything else.
Chris
jockwav
Re: Interleaving
Another check this morning. Grin
THIS IS STILL HIGH THOUGH Noise Margin (Downstream) 15.0 db
Re: Interleaving
Hi Jockwav,
You are achieving the fastest speeds your line can support,  the noise margin on your line is not an issue as your speeds cannot currently get any faster.
jockwav
Re: Interleaving
Ok thanks very much Chris. Grin
