Interleaving
Interleaving
I've just noticed that my router is showing that downstream interleaving is saying it's off at the moment - no bad thing in some ways and it seems stable. However, it would be useful to know if the DLM is still set to auto and has turned interleaving off, or whether it has been turned off manually.
Is there an easy way for PN to check what the current interleaving state of my line is. If it's on auto PLEASE LEAVE IT THAT WAY!  Smiley
jojopillo
Re: Interleaving
Hi nozzer,
I've turned interleaving on as requested..... joking!
It is currently off but set to auto, so it would only normally get applied if there was an intermittent fault.
Jojo Smiley
Re: Interleaving
Excellente as they say in Brazil!
Thanks Jojojojo.  Cheesy
