Interleaving
Ephemeral
Interleaving
I've got a button on my Connection Settings page that allows me to turn Interleaving on or off. I know it's something to do with correcting errors. Will leaving this on hamper my download speeds?
Fixes: 173
Re: Interleaving
If you have a bad line then interleaving helps with your downstream by, as you say correcting errors.
If you have a good stable connection turning off interleaving can reduce your ping times and increase your download speed (handy for gamers).
Customer and Forum Moderator. Windows 10 Firefox 63.0.3 (64-bit)
Ephemeral
Re: Interleaving
Would Interleaving turn itself off?
The reason I ask is that I have a support issue open at the moment as I'm having lots of disconnections and PN have kindly asked their supplier, which I'm assuming is BT, to turn Interleaving on. Are there different types of interleaving? Is the BT interleaving different from the on I get on my Connection Settings page? When I look at my Connection Settings page it says Interleaving is already on.
The bit that really confuses me is that I had a support issue, for the same reasons, about a month ago, and during that ticket it was also suggested that Interleaving would be turned on. So surely Interleaving should already be on.
*baffled*
Re: Interleaving
Quote from: Ephemeral
If it's set to off it shouldn't do, but by default it's set to auto which is usually on but can turn off if the line is stable enough. It looks like it's been on throughout for yourself, at least for the past couple of weeks that I can see the records for.
No different types, and it's the same one on the connection settings page as we've placed the order on from the fault. The order will have switched it from auto to on.
*baffled*
It's an automatic thing done as part of a fault, it doesn't get in the way or delay the response from the faults team in any way though. There's definitely a fair number of disconnections on the line and as long as they still occur in the master socket with all other items removed from the line then you've proved it's a line fault.
