Interleaving
slipthru
Interleaving
Is there a simple way to tell if i have switched on?
My pings are around 36 so am thinking it might be turned on.
Fixes: 123
Re: Interleaving
...by asking in here...which you have done. One of the Comms Team can tell you.
It also tells you in Routerstats depending on your router.
Customer and Forum Moderator.
slipthru
Re: Interleaving
Thanks interleaving is switched on.
