Interleaving
- Interleaving
- « Previous
- Next »
Re: Interleaving
10-06-2009 7:51 PM
Re: Interleaving
10-06-2009 8:15 PM
Quote Tracing route to newswww.bbc.net.uk [212.58.226.75]
over a maximum of 30 hops:
1 2 ms 1 ms 1 ms 192.168.0.1
2 35 ms 35 ms 45 ms lo0-plusnet.thn-ag3.plus.net [195.166.128.80]
3 46 ms 50 ms 34 ms vl303.thn-gw1.plus.net [84.92.3.177]
4 37 ms 49 ms 37 ms te2-3.thn-gw2.plus.net [212.159.1.58]
5 102 ms 193 ms 233 ms rt0.thdo.bbc.co.uk [212.58.239.25]
6 35 ms 38 ms 35 ms 212.58.238.149
7 36 ms 34 ms 33 ms 212.58.239.62
8 35 ms 35 ms 35 ms newslb306.telhc.bbc.co.uk [212.58.226.75]
Trace complete.
Re: Interleaving
10-06-2009 8:37 PM
Your connection has dropped 7 times today. Would I be right in thinking that that wasn't intentional?
Re: Interleaving
10-06-2009 8:40 PM
Re: Interleaving
11-06-2009 10:26 PM
Quote Today 22:25 4611 kbps (576kB/s) 379 kbps (47.4kB/s) Share
Today 22:22 5479 kbps (685kB/s) 381 kbps (47.6kB/s) Share
Today 22:16 4365 kbps (546kB/s) 379 kbps (47.4kB/s) Share
Today 22:12 3855 kbps (482kB/s) 379 kbps (47.4kB/s) Share
Today 22:05 5841 kbps (730kB/s) 379 kbps (47.4kB/s) Share
Compare this to the other speed tests i have done at this time and its a great improvement
Shouldnt have tempted fate
Today 22:27 2188 kbps (274kB/s) 381 kbps (47.6kB/s)
Re: Interleaving
12-06-2009 8:38 PM
Has anything changed on your end or bt's end recently?
Look at these tests
Today 20:46 6411 kbps (801kB/s) 373 kbps (46.6kB/s) Share
Today 20:43 5818 kbps (727kB/s) 323 kbps (40.4kB/s) Share
Today 20:37 6428 kbps (804kB/s) 382 kbps (47.8kB/s) Share
Today 20:36 6556 kbps (820kB/s) 382 kbps (47.8kB/s) Share
Re: Interleaving
12-06-2009 8:45 PM
Re: Interleaving
12-06-2009 8:47 PM
Hope so.
Re: Interleaving
15-06-2009 9:56 AM
A few thoughts here -
Do you leave rhe modem/router on 24/7?
Have a look at the router stats info and see if you can find a "Line Count" or "on-line time" or "WAN uptime" or anything similar.
You haven't got a sky box or anything similar, or a fax machine/answerphone that's not plugged into a filter have you?
If you start to see slow throughput speeds at peak times again run some tests at off-peak times (very early morning probably best).
Re: Interleaving
16-06-2009 6:09 PM
Speeds seem to be keeping constant
Quote Today 18:06 6155 kbps (769kB/s) 374 kbps (46.8kB/s)
To answer your questions.
1) I leave my router on 24/7 but do try to restart it every couple of days
2)
Quote System Up Time 23:14:25
Port Status TxPkts RxPkts Collisions Tx B/s Rx B/s Up Time
WAN PPPoA 71022 94997 0 182 1171 23:12:53
LAN 10M/100M 119029 137528 0 340 378 23:14:20
WLAN 11M/54M/108M 277131 214555 0 1639 521 23:14:15
3) No sky boxes or faxes. The only things plugged into the master socket is my router and a digital cordless phone.
Steve
- « Previous
- Next »
