Interleaving
bradw
Interleaving
Is there somewhere to check interleaving status on FTTC connection? Had another random latency bump last night of ~9ms (gone from ~8ms originally to ~26ms now)
And while on xbox (nothing else in use) latency went crazy and eventually disconnected completely - 3 of 4 router lights (all but power) were flashing in sync when I checked it, which seemed a little odd as they are usually random
Can see both here:
I'm guessing this is another "suck it up / wait and see what happens" as I'm sure there's still nothing that can be done. Sad
Almost worth going back to ADSL as I don't download much but want consistently low latency and stable connection (which I had with TalkTalk ADSL)
bradw
Re: Interleaving
What is going on
--- ntp.plus.net ping statistics ---
100 packets transmitted, 100 received, 0% packet loss, time 103900ms
rtt min/avg/max/mdev = 24.467/4241.573/12726.408/4166.128 ms, pipe 13
(That's 4 SECONDS average in 100 pings, full log here: http://pastebin.com/kpnd4cmd)
Again nothing really using the connection
bradw
Re: Interleaving
66 packets transmitted, 46 received, 30% packet loss, time 79642ms
rtt min/avg/max/mdev = 12928.975/15380.930/20339.258/1774.445 ms, pipe 21
--- bbc.co.uk ping statistics ---
60 packets transmitted, 60 received, 0% packet loss, time 59328ms
rtt min/avg/max/mdev = 25.461/16069.035/37516.832/13987.178 ms, pipe 38
Re: Interleaving
Interleaving has been turned on albeit at  the lowest level. From the graph you've linked to above it does seem after 6pm your line had very very high latency, was there anything in particular you were doing?
Are you connecting wireless or wired?
bradw
Re: Interleaving
The pings I posted were a seperate event at around 4am (yes, I work late!)
I was connecting wired at the time with wifi disabled, and only using skype (voice only)
Can see the 4am 'event' here.....with packet loss at various times too  Cry
Another thing I've noticed today, download has decreased again...
Download speedachieved during the test was - 25.07 Mbps
For your connection, the acceptable range of speedsis 16 Mbps-32.34 Mbps .
Additional Information:
IP Profile for your line is - 32.34 Mbps
