Interleaving - turned back on again
- Re: Interleaving - turned back on again
19-02-2014 9:38 PM
Hey There, I was wondering why my interleaving keeps getting turned back on my connection was stable for 16 days+ there but suddenly the Interleaving got turned back on again.
anyone aware why this would be? error on the line i dont see?
I do like it off for gaming etc..
thanks
thanks
Message 1 of 8
(1,018 Views)
7 REPLIES 7
19-02-2014 11:27 PM
ADSL2+ or FTTC?
Message 2 of 8
(652 Views)
19-02-2014 11:58 PM
Sorry ADSL2
dick:quote
dick:quote
Message 3 of 8
(652 Views)
20-02-2014 12:35 AM
If it ADSL2, it easy can be turned off after request
Message 4 of 8
(652 Views)
20-02-2014 9:57 AM
Interleaving has automatically been put on your line as DLM saw your line as being unstable.
<img src="http://community.plus.net/visualradius/generated/image13928901702064.png"/>
I'm not sure if the uptime you've seen is the uptime of your router as your connection has definitely dropped within the last 16 hours. We can remove Interleaving upon your request, however, it could cause the connection to drop further.
Message 5 of 8
(652 Views)
20-02-2014 2:06 PM
Hi Chris, thanks for the graph, I believe the 18 days stable was under interleaving off then it switched back on for some reason and the random drops was me trying to get my line at my maximum speed that's stable.
Yes can this be turned off please.
thanks
thanks
Message 6 of 8
(652 Views)
20-02-2014 2:19 PM
Sure- I'll get an order placed now.
Message 7 of 8
(652 Views)
20-02-2014 2:28 PM
That's been sorted for you.
If you might notice your connection drop, this will be the changes kicking in.
Message 8 of 8
(652 Views)
