Interleaving on 0r off?
harps1h
Hi PN
rather than raise a ticket for this is it possible to check if interleaving is on. If so is it possible to turn it off? I recieved the router yesterday and now have it running and all seems to be ok
Download speedachieved during the test was - 19.87 Mbps
For your connection, the acceptable range of speeds is 4 Mbps-21 Mbps.
IP Profile for your line is - 21.35 Mbps
there are no drops in the time it has been connected
Uptime: 0 days, 12:23:34
Harps1h Grin Grin
Fixes: 9
Re: Interleaving on 0r off?
If you can get in to the router stats to see the number of FEC errors being logged you can tell yourself. FEC errors only happen when interleaving is ON.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Hi harps1h,
Interleaving was set to Auto, not sure whether it was being applied or not (checking what jelv says above should tell you that) but I've placed an order to remove it anyway for you - it should complete tomorrow.
harps1h
Link Information
Uptime: 0 days, 16:03:13
DSL Type: ITU-T G.992.5
Bandwidth (Up/Down) [kbps/kbps]: 1,259 / 24,200
Data Transferred (Sent/Received) [MB/GB]: 132.81 / 1.21
Output Power (Up/Down) [dBm]: 12.3 / 0.0
Line Attenuation (Up/Down) [dB]: 2.9 / 8.0
SN Margin (Up/Down) [dB]: 6.3 / 3.0
Loss of Link (Remote): -
Error Seconds (Local/Remote): 27 / 0
FEC Errors (Up/Down): 0 / 0
CRC Errors (Up/Down): 28 / 65
HEC Errors (Up/Down): 50 / 2,706
Looks like it's not on currently then, but being on auto means it might turn on if something happens. The order I've placed should set interleaving to off, so it won't turn itself on automatically.
harps1h
you see this is why I like the folks at PN Towers  Wink
harps1h
interleaving still off it would appear
sjrinfroyle
It should be as Matt turned interleaving "off".
dick:quote
harps1h
sorry Freudian slip it should read as on
Fixes: 9
Have you started seeing FEC errors logged?
harps1h
no errors that's why I know it is not off
Fixes: 21
That's the wrong way round. It is off when there are no FEC errors. Matt's order will make sure it stays off.
Fixes: 9
Quote from: jelv
Fixes: 21
I suspect that was just a typo  Wink
harps1h
Maybe Matt can clarify
