Interleaving off
HaydnExport
Interleaving off
Hi , having had a stable connection for quite some time now , I'd like to try switching interleaving off again  Shocked  I know it could go belly up again , and maybe put it back on.  So can you please turn it off for me ? And if it all goes wrong could you switch it back on and reset my training period?
jojopillo
Re: Interleaving off
Hi HaydnExport,
I wouldn't recommend doing that to be honest bearing in mind how many problems you had previously. The reason it's probably been so stable is because of the way it's set up now.
Jojo Smiley
Fixes: 10
How many FEC errors is your router logging?
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
HaydnExport
dunno mate , my router doesn't show errors , netgear dgn2200.
Fixes: 10
Doesn't routerstats work with that router? On my Netgear the error counts are shown on the telnet page.
HaydnExport
it works , but there are no error counts on it, can plusnet see the errors?  If so what are they?
I've got what detail I can, basically in your latest session (ongoing 02:14:00:03 so more than 2 and a half days) there have been 2 errored seconds downstream and none upstream.
Upstream Link Info
Loop Loss | Loop Loss Add Text | SNR Margin | Errored Seconds | HecErrors | Cell Count | Speed
23.5      |                    | 9          | 0              | 0        | 24662558  | 832
Downstream Link Info
Loop Loss | Loop Loss Add Text | SNR Margin | ErroredSeconds | HecErrors | CellCount | Speed
51        |                    | 7          | 2              | 0        | 61656720  | 6976
Session | Logon identity | Start time          | Duration    | MB in  | MB out
Last    | <snip>        | 2011/03/11 18:15:21 | 02:14:00:03 | 424.31 | 776.42
All looking pretty good from here, to be honest Smiley
HaydnExport
Do you recon i could try interleaving off then?
HaydnExport
Pretty please?  Wink
Order placed and due to complete tomorrow Smiley
HaydnExport
thanks  Cheesy
HaydnExport
Will i need to reboot / disconnect for it?
I don't think so, it should just happen though I've checked on the order and it's not completed as yet. I'll keep an eye out for you.
HaydnExport
hi , it was done this morning, connection seems great my end, feels a lot better playing online !
Fantastic Smiley Glad to hear it.
