Interleaving - apparently turned off?
- Interleaving - apparently turned off?
05-05-2010 6:04 PM
Called up yesterday and was told interleaving was turned off on the 1st. Not according to my pings / router, though:
Pinging www.bbc.net.uk [212.58.246.159] with 32 bytes of data:
Reply from 212.58.246.159: bytes=32 time=32ms TTL=56
Reply from 212.58.246.159: bytes=32 time=33ms TTL=56
Ping statistics for 212.58.246.159:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 32ms, Maximum = 33ms, Average = 32ms
Pinging www-tmmdi.l.google.com [216.239.59.105] with 32 bytes of data:
Reply from 216.239.59.105: bytes=32 time=47ms TTL=52
Reply from 216.239.59.105: bytes=32 time=46ms TTL=52
Ping statistics for 216.239.59.105:
Minimum = 46ms, Maximum = 47ms, Average = 46ms
Also my router is saying:
Parameters
DSP Firmware Version E.25.41.55 A
Connected true
Operational Mode G.Dmt.BisPlus
Annex Type AnnexA
Upstream 450000
Downstream 11242700
Elapsed Time 0 day 2 hr 13 min 20 sec
SNR Margin(Upstream) 18.5 dB
SNR Margin(Downstream) 13.50 dB
Line Attenuation(Upstream) 28.0 dB
Line Attenuation(Downstream) 31.0 dB
CRC Errors(Upstream) 0
CRC Errors(Downstream) 0
Latency(Upstream) Interleave
Latency(Downstream) Interleave
I've disconnected and reconnected a bunch as I've been playing with settings trying to squeeze some more juice out of the line. So it should have picked up any changes if that was what was needed. Would you agree interleaving is still on? I have a 'My question' logged but I thought I'd float it here as the responses here seem unusually relevant and focussed for an internet forum.
Re: Interleaving - apparently turned off?
05-05-2010 7:13 PM
05-05-2010 9:44 PM
Here some recent pings (just now - 21:48):
>ping www.theregister.co.uk
Pinging www.theregister.co.uk [212.100.234.54] with 32 bytes of data:
Reply from 212.100.234.54: bytes=32 time=81ms TTL=56
Reply from 212.100.234.54: bytes=32 time=33ms TTL=56
Reply from 212.100.234.54: bytes=32 time=41ms TTL=56
Reply from 212.100.234.54: bytes=32 time=40ms TTL=56
Ping statistics for 212.100.234.54:
Minimum = 33ms, Maximum = 81ms, Average = 48ms
>ping www.bbc.co.uk
Pinging www.bbc.net.uk [212.58.244.141] with 32 bytes of data:
Reply from 212.58.244.141: bytes=32 time=69ms TTL=55
Reply from 212.58.244.141: bytes=32 time=32ms TTL=55
Reply from 212.58.244.141: bytes=32 time=34ms TTL=55
Reply from 212.58.244.141: bytes=32 time=46ms TTL=55
They can't be right, can they?
05-05-2010 10:15 PM
Reply from 212.100.234.54: bytes=32 time=22ms TTL=56
Reply from 212.100.234.54: bytes=32 time=20ms TTL=56
Reply from 212.100.234.54: bytes=32 time=27ms TTL=56
Minimum = 20ms, Maximum = 27ms, Average = 22ms
Reply from 212.58.244.141: bytes=32 time=20ms TTL=55
Reply from 212.58.244.141: bytes=32 time=24ms TTL=55
Reply from 212.58.244.141: bytes=32 time=21ms TTL=55
Ping statistics for 212.58.244.141:
Minimum = 20ms, Maximum = 24ms, Average = 21ms
Cheers
Paul
06-05-2010 8:04 AM
06-05-2010 8:29 AM
13-05-2010 11:33 AM
I've dug out some detailed stats from my Billion BiPac 7402NX - surely these prove it's on? I've asked for it to be toggled 'on' and back off (ticket 33336679 refers).
There's lots to do with interleaving in there and FEC errors:
I suppose, with all these errors, should I be having it turned off? A MW2 edge is a MW2 edge though...
LocalFastChannelRxRate = 0
LocalFastChannelTxRate = 0
LocalFastChannelFEC = 0
LocalFastChannelCRC = 0
LocalFastChannelHEC = 0
LocalFastChannelNCD = 0
LocalFastChannelOCD = 0
LocalFastChannelLCD = 0
LocalInterleavedChannelRxRate = 9079400
LocalInterleavedChannelTxRate = 786000
LocalInterleavedChannelFEC = 0
LocalInterleavedChannelCRC = 0
LocalInterleavedChannelHEC = 0
LocalInterleavedChannelNCD = 0
LocalInterleavedChannelOCD = 0
LocalInterleavedChannelLCD = 0
InterleaveDpDn = 64
InterleaveDpUp = 8
LocalMgmtFEC0 = 22966677
LocalMgmtCRC0 = 91
14-05-2010 10:34 AM
It's on, without a doubt (BT pages confirm). Do you want to try the connection with it off? I'm not sure we'd be happy just toggling on and off in a 48 hour period to be honest as we get charged for each order.
14-05-2010 11:10 AM
There's a previous ticket of mine to do with this where an agent has said he's double and triple checked my line and it's definitely off. Don't know what's happened there..
Merci beaucoup!
14-05-2010 11:50 AM
14-05-2010 12:19 PM
This overhead means you won't download at the fastest possible speed because some of your bandwidth is used by the error correcting packets, but more importantly (for gamers) there's an increase in latency (packet speed) because the packets are (excuse the n00bism here) kind of split up into smaller packets before they can be sent or fully received.
Happy to be corrected but that's my understanding of it!
Executive summary: Turning interleaving off (FastPath) can give you more throughput and faster speed, but at the expense of stability.
Edit for typo fixing.
14-05-2010 12:22 PM
The 'downside' is that latency is increased which is not a problem with normal web browsing but is with gaming.
Therefore having it turned off reduces latency (ping times) and can enhance the gaming experience.
Edit: as a footnote to what r3fl3x has said.
14-05-2010 12:24 PM
14-05-2010 12:55 PM
Order placed and due to complete Monday for you.
14-05-2010 1:36 PM
dick:quote
